20 Most Recent 2000 Ford Focus Questions & Answers
Ford 6000 cd unlock code?
Hi Tristian just put the code into a decoder i have and it gave me 3129 as the code have a try cant hurt and if it works the brews are on you!!!
Col.
2/28/2024 12:12:41 PM • 2000 Ford Focus • Answered on Feb 28, 2024
2answers
2000 Ford Focus Heater fan not turning on. Blows
Hi John,This should be fairly simple. I have uploaded a PDF file to Filesonic.com that contains both the Power Distribution Diagram for Fuse #64 and the Heater Circuits for your 2000 Ford Focus. You can download this file for FREE at the link below. Please note that if you do not have an account with Filesonic, you can still downdload the file for free, but you must use the "Slower Download" link at the bottom of the page. You will then see a timer running in about the center of the page. Once the timer runs out, it will give you a captcha code to enter in order to start the download. This file will only be available on Filesonic for 3 days, so you might want to save a copy to your computer for future reference.http://www.filesonic.com/file/3040758464/2000_Ford_Focus_Heater_Circuits.pdfOnce yo have the file, you can clearly see that the ONLY thing that is powered by that fuse is the blower motor. That makes this task very easy.Most likely, the blower motor itself (or the solid state circuits built into it) are shorted. Here is how we PROVE it before going out and buy a blower motor:1. Unplug the blower motor connector. Replace the fuse with the connector disconnected. If the fuse blows, then the GREEN/ORANGE wire between the fuse and the blower motor is shorted to ground. You will have to follow this wire from the blower motor back to the fuse block to find out where it is shorted.2. If the fuse does not blow, then take a test light (make sure it uses an incandecent lamp - the LED type will not work for this purpose) and connect it between the GREEN/ORANGE wire (ignition switch ON) and the BLACK/RED wire at the blower motor connector. Using the blower motor speed control switch, the lamp should not light at all with the switch in the OFF position. Then it should light and get brighter with each step as you move the switch toward the HIGH position. If this all works as described, then we have just proven that all of the circuits are good and that you need to replace your blower motor.3. If anything does not work exactly as described, tell me what it is doing that is different, and we can continue diagnosis if needed.Hopefully, this is all the information you need, but if you do need anything else, please let me know.Please also remember to take a moment and rate my service through the FixYa web site.Thank you for your patronage,-Dave (dttech)
9/21/2023 7:36:37 AM • 2000 Ford Focus • Answered on Sep 21, 2023
2answers
2000 Ford Focus ZX3. Does anyone have a diagram of the vacuum lines and connectors for it please?
Question edited for clarity. Question moved to model category. Check out the link https://www.google.com/search?q=2000+Ford+Focus+ZX3.+diagram+of+vacuum+lines ..
12/1/2022 9:43:34 PM • 2000 Ford Focus • Answered on Dec 01, 2022
2000 Ford Focus blower still not working after changing blower motor, fuse, and resistor?
Yes, it is likely an issue with the switch. It you can find the wiring diagram for it, you can test it for continuity with a multimeter.
10/23/2022 7:24:40 PM • 2000 Ford Focus • Answered on Oct 23, 2022
3answers
Need radio code for 1999
The serial number is on a label at the back of the radio. With this model you must remove the radio from the dash to find it.
If it is a European Ford the serial will look like M123456. You can try this site for the code once you have the serial as they are cheap and reliable for decoding Fords.
Otherwise your local dealer will get you this code for around £25.
See video below for instructions on removing the radio.
Thanks for using FixYa and please do leave a vote for the solution.
10/1/2022 2:48:33 PM • 2000 Ford Focus • Answered on Oct 01, 2022
3answers
00 ford fiesta,, heaters,electric windows and
have exact same problem myself checked all fuses they are fine & my car is a ford fiesta yr 2000 model Ghia gonna have a look at the 50amp fuses
Any1 else out there have a possible solution. If this 1 dont work
4/29/2022 8:27:31 AM • 2000 Ford Focus • Answered on Apr 29, 2022
Brake line diagram 2000 Ford Focus zts
4/13/2022 4:56:55 PM • 2000 Ford Focus • Answered on Apr 13, 2022
3answers
Timing belt broke -2000 ford focus zx3
Hello mawbea: My name is Roger I will answer your question. You did not say which engine is in your car. So if you have a 2.0 SOHC engine. If the belt broke you should be Ok. If you have the 2.0 DOHC engine. The likely hood of bending the valves are just about a guarantee. How ever with any engine using a timing belt it is possible to bend a valve.Should you need more help please just ask.
Please rate the quality of your answer as this way we know you received helpful information.Thank You for using Fix Ya, Roger
11/26/2021 2:06:46 AM • 2000 Ford Focus • Answered on Nov 26, 2021
2answers
How to open door on ford focus when neither handle will open it?
Just go through the procedure to remove the inner door panel and then you'll see the actuator rod that goes from the door handle to the latch. Just spray the acuator rod at the door handle end and the latch end with a shot of pb blaster (wd-40 will also work) to clean and loosen it up. I did that very thing last week and the door works like a new one. The hardest part of the whole door panel removal is the mirror cover and the cover on the actual door handle. You have to remove the cover on the door handle to see the two 1/4" bolts that hold it on. Still a very easy job for the basic do-it-yourself kind of guy....mine took less than an hour (maybe just a bit longer) to take apart and put back together. At any rate it's still cheaper than taking it to a dealer so they can do the same exact thing and charge you 75-80 bux to fix it the same way. See uf this helps
11/19/2021 9:43:43 PM • 2000 Ford Focus • Answered on Nov 19, 2021
2answers
Ford focus 2000 lovation of fuel filter anhow to replace
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today They have full manuals and it's verrrrry cheap and mine I got free in offers 3rd time I bought it, I also had an issue with the file so the girl replaced it in 30 mins there is one website more but i don't remember its name it was 2 years back bitman something link this Try these out brother
9/13/2021 8:11:23 AM • 2000 Ford Focus • Answered on Sep 13, 2021
5answers
Where is fuse 64 located?
Check the user manual, it will show position of fuse box and location of fuse 64 With the correct amperage for that fuse.
8/29/2021 12:00:20 PM • 2000 Ford Focus • Answered on Aug 29, 2021
2answers
I have a 2000 Ford Focus 2.0 spi idles rough and loud and throws code po300. I have swapped coil pack,spark plugs, and plug wires but still no change. How can I find the problem and fix it?
Misfires aren't just caused by spark plug issues. You could have a problem with one or more sensors on the engine, a fuel supply issue, A vacuum leak, a PCV valve problem or a more serious issue with the actual parts inside the cylinders themselves. Did it throw any other codes? Does it do anything else wrong? (like stalling or very smoky exhaust gas). Unless your familiar with working on engines I would recommend getting a good mechanic to look at this. They'll be able to look and listen to the engine for more clues to what the problem is.
3/21/2021 9:53:11 PM • 2000 Ford Focus • Answered on Mar 21, 2021
3answers
Ford focus fuel pump not working
There should be a reset button on a part called an Inertia switch. This switch is located behind the front kick panels or in the trunk.The Inertia switch is a safety switch used to prevent fires after a collision. But sometimes if the right Frequency is generated by closing a door, hood, or trunklid the switch will activate. Then power is cut off from the fuelpump.
2/26/2021 2:59:08 AM • 2000 Ford Focus • Answered on Feb 26, 2021
2answers
My gear stick on my 1.8 ford focus zetec has gone
sounds like broken gear cable they are to not to had to fix
12/17/2020 4:56:02 PM • 2000 Ford Focus • Answered on Dec 17, 2020
2answers
Fitting a clutch
thats a job one of two ways to do that pull the motor and tranny as a unit or drop the cradel i dont think there is room to seperat them in the eng bay hope this helps
11/27/2020 8:36:58 AM • 2000 Ford Focus • Answered on Nov 27, 2020
Ford focus power door lock fuse location
I have a 2007 basic ford focus having problems pairing auto door unlock? Where is fuse. Thanks
3/7/2020 4:53:17 PM • 2000 Ford Focus • Answered on Mar 07, 2020
3answers
Radio code from vin number WF0AXXGBBAYC16620
un fotunately you can't get radio code from chassis no. you need unit out don't know what unit you have it will be either m serial no (older unit) or v serial no.(newer unit) could only suggest taking to ford dealer & get them to remove unit to get serial no.
1/2/2020 5:14:52 PM • 2000 Ford Focus • Answered on Jan 02, 2020
9answers
Ford Focus vibration from the front end 50-70mph
I am betting on a tire balance. I have had tires out that only vibrate at 60; they were pretty smooth at 75.
11/5/2019 7:14:31 AM • 2000 Ford Focus • Answered on Nov 05, 2019
Front right disc and rear right drum 2000 focus will not bleed out
Very good write-up. I certainly love this website. <a href="http://lambingantv.co"> Bepanah Pyar </a> <a href="https://bepanahpyaar.org/"> Vish </a>
8/16/2019 3:34:21 PM • 2000 Ford Focus • Answered on Aug 16, 2019
5,166 questions posted
Popular Products
2001 Ford Focus
2001 Ford Focus
2,612 Questions
2003 Ford Focus
2003 Ford Focus
2,055 Questions
2005 Ford Focus
2005 Ford Focus
1,226 Questions
2004 Ford Focus
2004 Ford Focus
897 Questions
2006 Ford Focus
2006 Ford Focus
840 Questions
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
View Most Popular
Focus Ford
  • Focus Ford
Most Popular Question
fitting clutch
  • Cars & Trucks
