20 Most Recent 2000 Chevrolet Blazer Questions & Answers
2000 Chevy Blazer. It started back firing and running rough and then just quit. I had to put a new distributor, cap and rotor button on it but I'm getting no spark.
Help in the link, but it could be anything. https://www.google.com/search?q=2000+Chevy+Blazer+no+spark A half hour with an auto electrician is the most cost efficient way to fix. A professional grade scan tool computer can diagnose all the electronics and electrical sensors. https://www.google.com/search?q=mobile+auto+electrician+near+me ..
2/17/2024 12:56:44 AM • 2000 Chevrolet... • Answered on Feb 17, 2024
Where are the freeze plugs located on a 2000 Chevy blazer.
This is the easiest way to answer this question. https://youtu.be/2zdnd5ikynU?si=4QKEWGo4BdyxnDxf
10/15/2023 1:33:19 PM • 2000 Chevrolet... • Answered on Oct 15, 2023
2answers
2000 s10 blazer back wipper won't work no washer
fuse or broken wire
9/28/2023 11:04:45 PM • 2000 Chevrolet... • Answered on Sep 28, 2023
Is the front passenger axle nut threads reversed ?
Axel with reverse threads should be on the driver side or the passenger side
1/15/2023 5:56:45 PM • 2000 Chevrolet... • Answered on Jan 15, 2023
5answers
2000 Blazer stuck in 4WD
The first thing I would look at is the shift rod on the transfer case. If I remember correctly, it is on the drivers side and is a rod aboutsix inches long and has two ends that basically pop into rubber gromets. If that rod is bent in any way, or has come loose of the gromets, it will not shift into or out of the four wheel drive. If yours has electronic four wheel drive, the electric acutator could be out or going out. you should be able to remove the rod and simply move the switch by hand on the transfer case. It will get you out of 4 wheel drive until you have the ime to diagnose the electronics at least. It has happened to both my 1994 and 1999 S-10 blazers.
1/10/2023 6:13:20 PM • 2000 Chevrolet... • Answered on Jan 10, 2023
Car runs rouhg at 50 mph
o.k... question... when you punch it... does the car barely go... and the engine reve up? if you gently press the gas... does is act the way it's suppose to? if that's what you have... change out the fuel pressure regulator... and the fuel injector... see if that doesn't work for you... o.k... good luck to you
12/1/2022 11:00:22 PM • 2000 Chevrolet... • Answered on Dec 01, 2022
2answers
How many quarts of transmission fluid needed for
according to the chart 11 pts. where 2 pts. = 1 quart, so it's like 5 quarts and a half. But, all capacities are approximate, it says, so check on level ground, warmed up, for full level of transmission fluid.
10/31/2022 7:28:17 PM • 2000 Chevrolet... • Answered on Oct 31, 2022
4answers
Have 93 chevy s10, stopped and started just fine
the other wire that is "dead" is the ground wire for the fuel pump. try cutting that wire after the connector towards the pump, and running it to a good clean ground.
5/26/2022 8:09:49 PM • 2000 Chevrolet... • Answered on May 26, 2022
Coolant leaking from passenger side of engine
Yes there would be a welsh plug in that area and it is probably rusted out.
4/9/2022 12:54:07 AM • 2000 Chevrolet... • Answered on Apr 09, 2022
2answers
Rear hatch and window won't open on Blazer
sounds like a blown fuse, open drivers door and look at side of dash, fuse panel is there check fuses
2/23/2022 4:30:31 PM • 2000 Chevrolet... • Answered on Feb 23, 2022
2008 Chevy Malibu Classic LS. Is there a fuse for brake lights?
No there isn't. The Body Control Module (BCM) takes care of that. Check the grounds that are near the rear light, but you will need a good auto-electrician with a professional grade scan tool computer to check the BCM functions. Here is your Fuses and Relays.
Fuse Box Diagram Chevrolet Malibu (2008-2012)
https://fuse-box.info > chevrolet > chevrolet-malibu-20... Here you will find fuse box diagrams of Chevrolet Malibu 2008, 2009, 2010, 2011 and 2012, get information about the location of the fuse panels inside the car, ...
2/5/2022 1:45:54 AM • 2000 Chevrolet... • Answered on Feb 05, 2022
2000 blazer. when hazards are on but not flashing, there are no brake lights (except center). when stalk is set for right turn but not blinking only left brake light works and vice versa
The best solution you'll get from b ooks at www.reliable-store.com These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
11/19/2021 9:03:51 PM • 2000 Chevrolet... • Answered on Nov 19, 2021
I need a firing order diagram for a 2000 Chevy
11/6/2021 10:51:11 PM • 2000 Chevrolet... • Answered on Nov 06, 2021
4answers
What years 4.3 vortec will fit in my 2000 Chevy
The years of 1996 to 2002 with the engine code L35. Just becareful that the year 2002 is the change over year from L35 to LU3. The L35 fuel system is the SCPI (Sequential Central Port Injection)  The LU3 fuel system is the MPFI (Muilti Port Fuel Injection)
Good luck and hope this Helps.
10/22/2019 1:35:51 PM • 2000 Chevrolet... • Answered on Oct 22, 2019
2answers
Do all 2000 chev blazer 4x4 have rear disc brakes
they should --but your parking brake is considered drum and shoe
8/15/2019 7:24:22 AM • 2000 Chevrolet... • Answered on Aug 15, 2019
2000 blazer will not start did a manifold gasket job, replaced plugs, wires, distributor cap,new fuel filter. Cranked and ran really good for 2 days then will not crank
Check you starter, maybe you have a loose connection. Try to give direct power to the starter and see what's happening. I nothing happens, you have a bad starter.
8/7/2019 10:29:13 PM • 2000 Chevrolet... • Answered on Aug 07, 2019
Torque specs 2000 4.3 rocker arms
One thing I notice that none of the experts are picking up on is that these trucks although appear the same and have the same size motor is that they changed in 2000 to 2004 from the previous engines, the rockers and lifters are different and the specs and procedures different, so if you ask for advice for your 2001 and someone responds from their experience on their 99 or 97 it's not valid information.
7/19/2019 1:45:09 AM • 2000 Chevrolet... • Answered on Jul 19, 2019
Took my 2000 chevy blazer for an emissions test and it failed with code P0340-Camshaft sensor A circuit (Bank 1 or Single Sensor)what does this mean? What do I need to do or have done?
you can get guide from many sites.. i know few like one is https://www.reliable-store.com/ error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered within seconds u can get the access and it's totally illustrative complete
6/26/2019 7:11:15 AM • 2000 Chevrolet... • Answered on Jun 26, 2019
2000 Chevrolet Blazer Logo
3,418 questions posted
Popular Products
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
View Most Popular
Blazer Chevrolet
  • Blazer Chevrolet
Most Popular Question
years 4 3 vortec will fit in 2000 chevy
  • Cars & Trucks
