20 Most Recent Intuit QuickBooks Pro 2008: Windows Questions & Answers
5answers
I am getting error codes 6129,0 and 6073, 816 on
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
12/13/2023 6:22:56 AM • Intuit... • Answered on Dec 13, 2023
4answers
Error codes -6144, -82 Cannot connect to the
http://support.quickbooks.intuit.com/support/Articles/SLN53503
11/18/2022 6:31:47 PM • Intuit... • Answered on Nov 18, 2022
Why is quickbooks unable to create the data to send email?
Follow this discussion on Intuit Official site http://support.quickbooks.intuit.com/support/articles/SLN41016 and if not able to understand technical aspect then get some guidance from Intuit Tech Support .
11/2/2022 7:26:27 AM • Intuit... • Answered on Nov 02, 2022
Backup not responding
Intuit recommends 2 solutions for this problem. The first solution may solve your problem, or you may need to try both to resolve the issue. For best results, perform the solutions in the order shown. Solution 1: Download QuickBooks File Doctor Download, install and run the QuickBooks File Doctor. If you see No problem detected in your Company File, and you still experience the issue, go to solution 2. Solution 2: Check for data damage. Perform the standard data damage troubleshooting. for more help visit QuickBooks Tech Support
11/1/2022 5:51:00 AM • Intuit... • Answered on Nov 01, 2022
2answers
Password rest problem quickbooks pro2008
try the suggestions given at this sitehttp://support.quickbooks.intuit.com/support/Articles/SLN41478
9/27/2022 9:20:42 AM • Intuit... • Answered on Sep 27, 2022
2answers
Help for reseting password
If you're resetting another type of password: These articles may help:
  • QuickBooks User: QuickBooks users added by admin
  • Intuit Account: Used for many Intuit services including Registration
  • QuickBooks File Manager Password Vault: Used by QuickBooks File Manager
  • Closing Date: Prevents editing of transactions in prior periods
  • Windows User: Used by QuickBooks for scheduled backup
  • Online Banking password: Provided by your financial institution
  • Customer Credit Card protection: Required security standards
  • for more help visit
9/23/2022 10:31:24 AM • Intuit... • Answered on Sep 23, 2022
3answers
Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
9/14/2022 8:30:48 AM • Intuit... • Answered on Sep 14, 2022
4answers
How to install QuickBooks on a server ?
Please call quickbooks (844) 414-4868
9/11/2022 5:09:03 AM • Intuit... • Answered on Sep 11, 2022
3answers
I am trying to instal quickbooks pro 2008 but
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
9/2/2022 5:08:55 AM • Intuit... • Answered on Sep 02, 2022
2answers
3answers
Error code 3371 status code
http://support.quickbooks.intuit.com/support/articles/sln40318
7/7/2020 1:17:47 PM • Intuit... • Answered on Jul 07, 2020
2answers
Missing configiration file quickbooks
You can just uninstall quickbooks and reinstall it. Possibly you can just put in the disk and it should find the file you are missing.
3/14/2020 11:41:39 AM • Intuit... • Answered on Mar 14, 2020
2answers
We had a problem with
QuickBooks support is here
3/14/2020 11:38:11 AM • Intuit... • Answered on Mar 14, 2020
6answers
Quickbooks Pro 2008 Payroll problem
I had to reinstall Quickbooks 2008 on a Windows installation that never had it on there before (virtual machines are handy) and now it works again. I am staying far away from letting it upgrade to latest; that's how my troubles started. I also doubt I will ever shell out money for a more recent version; I upgraded from 2005 to 2008 and it took away the ability to do automatically do IRS 941 forms if you don't pay for monthly payroll services. There has to be better accounting software that doesn't leave users stranded at year-end.
7/23/2018 9:31:17 AM • Intuit... • Answered on Jul 23, 2018
Unable to create pdf in Quickbooks 2008 pro
To make sure you do not encounter PDF issues in the future, always make sure you are on the latest release of QuickBooks. go to this link Unable to reconcile accounts or to create print or email pdf files and follow the steps for under How to fix it for 2010 and older QuickBooks versions only and if need any help follow http://www.techsupportquickbooks.com/intuit/ .
1/3/2017 7:12:02 PM • Intuit... • Answered on Jan 03, 2017
How i get the Detail Overview About Banking Terminology In Quickbooks ?
Hi John Later, I understand your Problem but I want tell You Its So long Process for this. we want help to you. you can see all details here :- http://www.securesoftllc.com/ or call :- 1-855-588-6312 24 7 Online Tech Support For QuickBooks get-detail-overview-about-banking-pbpygufiebmqlrf1uew3q00y-2-0.jpg
1/27/2016 10:22:15 PM • Intuit... • Answered on Jan 27, 2016
Are there any problems associated with this program?
Please call quickbooks (844) 414-4868 & have a tech help you so you dont loose sensitive info.
12/15/2015 7:05:29 PM • Intuit... • Answered on Dec 15, 2015
2answers
Free Quickbooks Pro Tutorial
check out here put your download query here and search. Downloadanystuff.org/ for refine your search go different category with
your download search query
12/15/2015 12:56:00 PM • Intuit... • Answered on Dec 15, 2015
Validation code
Only Intuit can generate a validation code.
7/8/2015 6:05:30 PM • Intuit... • Answered on Jul 08, 2015
Intuit QuickBooks Pro 2008: Windows Logo
184 questions posted
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
QuickBooks Intuit
  • QuickBooks Intuit
Most Popular Question
change pound sign euro sign
  • Computers & Internet
