20 Most Recent SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Questions & Answers
4answers
Am trying to transfer DVD disc to Sandisk flash
it sounds like you need to creat an .iso file from the dvd then drac and drop. is you flash drive 4 Gb
9/6/2021 2:52:27 AM • SanDisk Cruzer... • Answered on Sep 06, 2021
How can I bypass my own password?
A password supposed to save guard your drive. What good would a password be, if you could override it? There are programs on he net, that could unlock a password protected file or drive, but only as long as the password is simple. That means just a few characters. As long as you don't have acces to the programs the secret services of the world suppose to have, you won't be able to access your jump drive. Sorry
1/12/2020 2:33:16 PM • SanDisk Cruzer... • Answered on Jan 12, 2020
2answers
Data Recover
8/27/2018 6:08:50 AM • SanDisk Cruzer... • Answered on Aug 27, 2018
Service center in chandigarh
I'm not in India but I can use a search engine.
http://www.zyxware.com/shop/computer-hardware/flash-memory-and-card-readers/pen-drive/bootable-fedora-12-4gb-sandisk-usb-memory-stick
Here, 4MB USB drives are very inexpensive and not worth the trouble to try and exchange them. I think they're less that $30 U.S.
12/15/2017 6:53:57 PM • SanDisk Cruzer... • Answered on Dec 15, 2017
Pdf files on my flash drive won't open
Try to get a later copy of Adobe reader or get "Open Office" from GNU and try to read it Microsoft software is prone to do this out of my own experience and made me swear like a proverbial sailor
10/1/2017 6:23:46 PM • SanDisk Cruzer... • Answered on Oct 01, 2017
Cant boot from usb. sandisk cruz 4gb
These answers are garbage. You should be using "Roofus," you won't have to do any of that fancy formatting stuff. You can just select the drive and ".iso" file in the program and begin burning. https://rufus.akeo.ie/
6/28/2017 7:45:21 AM • SanDisk Cruzer... • Answered on Jun 28, 2017
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
9/22/2016 3:37:29 AM • SanDisk Cruzer... • Answered on Sep 22, 2016
2answers
Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
10/13/2015 1:36:58 AM • SanDisk Cruzer... • Answered on Oct 13, 2015
2answers
Deleted a folder containing files by mistake on my 4GB Sandisk Cr
Yes, one good way to recover deleted folders and files from Sandisk Cruzer is to use a Sandisk data recovery software. See this step by step guide How to recover deleted files from SanDisk Cruzer You may also try this guide http://forum.001-software.com/pbb/viewtopic.php?f=4&t=13 hope this helps.
8/28/2015 9:47:49 AM • SanDisk Cruzer... • Answered on Aug 28, 2015
4answers
My all folder in flash d change to be shortcut
Is this the Problem???Only Shortcuts,,,,,, _68.gifDon't format your Flash Drive.Your data is still there.Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.DOWNLOAD !! http://shortcutvirusremover.blogspot.com
7/21/2015 9:57:04 PM • SanDisk Cruzer... • Answered on Jul 21, 2015
Pen drive not detected by my laptop
Your AV software may have created an block for your drive for some reason. You'll need to go in there and remove that block and then you should make an exceptionso it does not see your pen drive as a threat again.
11/26/2014 9:31:37 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
2answers
4 gb usb creating shortcuts
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
10/19/2014 12:12:34 PM • SanDisk Cruzer... • Answered on Oct 19, 2014
I have some info on a cruzer sandisk that I want to share with someone. How do I copy onto a dvd?
Insert into computer copy file then burn to DVD
9/27/2014 6:19:36 AM • SanDisk Cruzer... • Answered on Sep 27, 2014
mon usb ne fonction pas es pc ne pas formater
7/29/2014 6:44:45 AM • SanDisk Cruzer... • Answered on Jul 29, 2014
Cherry mobile
It's damaged. Get a new one.
4/7/2014 9:51:46 PM • SanDisk Cruzer... • Answered on Apr 07, 2014
My memory card showing recyclic error
Copy all the files onto your computer. Then reformat the card, to identify and bypass the "bad" spots of memory. Note that flash-drives have a limited life-time -- after too much usage, you will be able to "read", but not "write" to the device. This is a sign that the device is "dying", and should not be trusted with "valuable" data.
3/16/2014 6:13:33 AM • SanDisk Cruzer... • Answered on Mar 16, 2014
2answers
Can a sandisk 16gb flash drive be repaired?
Try the flash drive in another computer, and if the problem is still there, the product may be corrupted.If the product is still in it's warranty period, you should go to the manufacturer's service center, and they will replace it free of cost. If the warranty period is over, just buy a new one.Hope this helps, Mrityunjay.
2/18/2014 11:25:21 PM • SanDisk Cruzer... • Answered on Feb 18, 2014
3answers
I m getting problem with
I m getting problem with IOCTL error with my sandisk 1gb pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
2/4/2014 3:13:55 PM • SanDisk Cruzer... • Answered on Feb 04, 2014
Code -0500
hi nice soft
2/1/2014 8:55:15 AM • SanDisk Cruzer... • Answered on Feb 01, 2014
Remove Write Protection
To remove write protection: Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor. Navigate to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies Double click the key WriteProtect in the right pane and set the value to 0 In the Data Value Box, press OK Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
12/24/2013 12:17:58 PM • SanDisk Cruzer... • Answered on Dec 24, 2013
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
500 questions posted
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
Cruzer SanDisk
  • Cruzer SanDisk
Most Popular Question
data recover
  • Electronics - Others
