20 Most Recent Passport 9500i Radar/Laser Detector Questions & Answers
Escort Qi45 not picking up laser signals
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try free
1/23/2019 11:53:53 AM • Passport 9500i... • Answered on Jan 23, 2019
Where can I buy speaker for Passport 9500xi
Ebay I seen one just this week 9/15/14
9/20/2014 3:21:58 PM • Passport 9500i... • Answered on Sep 20, 2014
How do i replace a broken speaker in passport 9500i
The speaker is manufactured by PUI, but it is a custom OEM job for Escort. So you can't get it from any distributor or from PUI. In the late summer of 2007 Escort started installing a new "high temp" speaker. This new speaker looks just like the original speaker, but it is designed to be able to handle very high temperatures without blowing. If your 9500i is still in warranty, Escort will replace the speaker with the new "high temp" speaker, test and calibrate your 9500i, and install whatever their latest firmware is. If your 9500i is out-of-warranty, then you should call them and see if they will send you a replacement "high temp" speaker for a small charge. The speaker is easy to replace. A good while back I posted on radardetector.net detailed instructions on how to replace a 9500i speaker. It takes all of 10 minutes to do.
5/28/2014 1:39:11 AM • Passport 9500i... • Answered on May 28, 2014
I plug my cord into the cigarette lighter. It will flash for a second then in is off. It will not power on the radar. I opened the plug but I did not see a fuse. Any help?
Have you tried unit in another cars plug-in? There should be a fuse between the silver tip of the plug and the wires connected to it. I would determine if the plug in is bad then the plug itself. If plug in is dirty plug is not making good connection to power unit. Plug in is also protected by a fuse in your cars fuse box.
5/20/2014 12:25:39 PM • Passport 9500i... • Answered on May 20, 2014
I HAVE A PASSPORT 95OOi AND I AM HAVING A PROBLEM
This is most likely caused by either a somewhat flaky power connection inside or on the back side of your car's cigarette lighter socket, assuming that you are using your 9500i's standard coiled Smartcord, or it is caused by excessive alternator ripple (electrical noise). Usually installing the optional direct wire power cable resolves this issue. Also Escort can reprogram your 9500i to desensitize its laser circuitry, but it would be better to try the direct wire power solution first. The direct wire solution usually resolves this problem, especially if you tap power in your fuse box from one of the higher amperage fuse terminals such as 15A. Why? Because the higher amperage fuses have heavier cable leading directly back to your car's battery and tend to be more free of electrical noise.
10/3/2012 2:54:41 PM • Passport 9500i... • Answered on Oct 03, 2012
0answers
2answers
Looking for an online printable owners manual for
escortradar.com or 800 964 3138 they also have a pretty good tutorial about how detectors work and what the differences are for each different band go to the web side at the bottom of the home page click on ( radar school )
4/15/2012 2:33:07 PM • Passport 9500i... • Answered on Apr 15, 2012
Does the passport 9500ix unit have a fuse in the
  • There is no traditional fuse inside your radar. The only one that is protecting the wire is in the plug that goes into your cigarette lighter / ACC outlet. If your fuse blew and you replaced it with another 2 Amp or 3 Amp fuse and are getting no response I would start with the fuse that provides the power fuse to the outlet you were using when it blew. But no quick blow style fuse inside your radar.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
10/10/2011 4:02:09 AM • Passport 9500i... • Answered on Oct 10, 2011
0answers
Everything lights up and is working,but i have no
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
3/6/2011 4:46:46 AM • Passport 9500i... • Answered on Mar 06, 2011
0answers
The device says
detecting to much voltage at the power port check to make sur that the alternator is not over charging or board could be going bad i would suggest trying it on another car if it does it with another car then the board is going bad
5/6/2010 3:44:18 AM • Passport 9500i... • Answered on May 06, 2010
My passport is not detecting the ka band as it
police are wising up and updating their equipment. Alot of scanners are obsolete these days
11/18/2009 4:50:32 AM • Passport 9500i... • Answered on Nov 18, 2009
3answers
When I connect the chord to cigarette plug, the
try slightly turning the plugin in the the lighter socket. Some of these are touch. Or try to take the metal prongs on the plugin and gently pry them outwards just a bit for a better connection.
11/15/2009 5:56:05 AM • Passport 9500i... • Answered on Nov 15, 2009
Passport 9500i Radar/Laser Detector Logo
36 questions posted
Top Escort Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Escort Vehicle Parts & Accessories
Most Popular Question
smart cord just flashes
  • Vehicle Parts & Accessories
