20 Most Recent
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Questions & Answers
I have whirlpool duet gas
The
cycling or operating thermostatis often the problem when a
dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about
why a clothes dryer will get too hot.
Clothes Dryergetting too hotheatman101
My gas dryer has no heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101][[]][
Gas lights up for about
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Om dryer says control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the
Control Lock indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to
check the control for any stuck button and unstuck it if the control
still cannot be unlocked with the End of Cycle Signal
button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
I have a front loader dryer and the inside is
If you have washed some NEW blue denims, some of the dye will get on everything. Blue denims are often a pain, and if you wear them before washing them they will get that same blue dye all over you.
It didn't hurt your washer, just run a couple loads through and add a little bleach to the whites. Note that if you put bleach in with OTHER colors, they will fade.
The trick is, never wash ANYTHING with blue denims, especially when they're new.
The "Control Locked" is lit up and the control
Try holding down the CONTROL LOCK button down for about 3 seconds.
See if that works.
Comment back here if it doesn't and I will provide additional instructions if required.
Good luck.
Joe.
Why is my whirlpool duet
If
your dryer
is not drying
like it once did or if you just have not taken the time to give
yourself a clean
dryer
in a long time then you need to do that. At least once a year the
dryer
cleaning
should take place. Lint
build up
in the dryer
duct
is one of the main causes for your dryer to fail.
Here is the
rest of this tip about Dryer
Maintenance
heatman101
I have a whirlpool duet dryer. When running a
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
I have a whirlpool duet super capacity plus dryer
It appears your timer/main controller/CCU has failed in this instance.
Blue rubber glove in load stained dryer inside. How to clean?
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
I ahve a duet gas dryer and it will not get hot
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
My Whirlpool dryer has stopped heating-
if your heating element is good then you need to check the thermal fuses in the cabinet if one of those is bad then it needs to be replaced.all thermal fuse should have continuity as well as the element if one of them does not have any continuity then replace it
Duet gas dryer flame does not stay lite
The flame should cycle on and off in response to the thermostat. If it is going out and not coming back on several minutes later then the exhaust vent may be clogged. Check the lint filter and exhaust vent all the way to the vent outlet to make sure they are not clogged.
