20 Most Recent
AT&T Nokia 6555 Cell Phone - Black Questions & Answers
Phone won't charge, usb music sync on screen when
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
What if if i don't have a AT&T sim?can i still
To which network is it locked to?You can approach
Prounlocking.com and get the required unlock code for your Nokia 6555c.You need to specify the country,locked network and based on the availability get the unlock code along with free instructions.Through this method you need to unlock without any simcard.
Restriction code unlock
Hi,you can get the Restriction code from your service provider (or) some trusted online sites.After getting the code unlock your AT&T Nokia 6555 by following the easy step by step unlocking instructions given from
MobileUnlockGuide.com .
Update software
Ususally updates will download automatically. If you need to install the appropriate software on your computer connect phone and allow it to update
I want to need restriction code for nokia 6555
hi to get restriction code visit mobileunlcoksolutions.com here they ask you the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile .then visit
mobileunlockguide.com here they provide free instruction guide about how to use codes in your mobile.
I cant use other Zim
Hai..
Once you unlocked your mobile, you can use it anywhere in the world. I found an unlocking service at
Classicunlocking.com .This is the online service provider which provides the code at cheap price..Through this you can unlock your mobile easily..
What is the restriction code of nokia 6555b?
Your mobile is restricted to some network provider..Restriction code is used to remove the simlock..
There are many providers offer this restriction code..You can get the restriction code from your network provider or you may get it from online providers like
My phone shows serial number
It means your RPL/IMEI is corrupted,experience turn off the phone in a several minutes and can encounter errors in some functions.This is due to a wrong procedure of flashing or updating the phone firmware or wrong procedure on unlocking the phone network.Chances are,if the last person/technician ever back up the phone system data,possible to bring back the serial.If not,need an RPL service and this is available is some mobile service center.
