20 Most Recent
SanDisk 4GB microSDHC Memory Card Questions & Answers
My micro SD card is
You may need to use the diskpart command from the commanline on a Windows computer. Google "format disk fro m command line". Careful, you can ruin the computer if you do this wrong.
Remove password 5233
You say memory card... if that is so then look at the side of the card itself, you will see a little tab yellow in color maybe. Turn over the card to make sure you can read the info next to this tab; which should show an arrow and the word LOCK. Slide that tab in the opposite direction to unlock it.
Hey, my sim card wont
Hello, some older equipment only supports the SD card, not the SDHC one which although the same size and connections, functions differently. I think max size for a SD card is 2GB.
Regards,
nicam49
Hi---i've just bought a 4gb
in you video camera setting check where the files are getting stored
in gonna wanna be set to external storage or memory card
My sandisk memory card of 4gb shows 0 bytes how do
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management.
Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
4gb micro sd card says its "full" when its empty
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
How do you transfer a photo from computer to
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
