The best way to recover deleted photos from memory card is to use some memory card photo recovery software, a good one is asoftech photo recovery. You may refer to this guideMemory card photo recovery guidehope this helps.
The is a way to download the video on YouTube but the format is on FLV (Flash Video). I believe that there is no to few mobile phones that could play FLV formats.
go to computer direct the pointer to this pc right click and select (manage) it will take you to computer management select disc management and select the location of the drive you want format
This video shows a case where you lost audio files in SD card of camera or cell phone. In fact, data loss due to most reasons could be solved using RePicvid Free Photo Recovery, including formatted or corrupted device. Check this video and know about how to recover lost audio files from SD card.
I had the same problem. The chip is faulty and should be replaced by the store that you purchased the chip. This is no fault on your part and by the way the chip I had was also 4 GB
Hi! Maybe what you're talking about is the 'Autoplay' feature of the computer. Autoplay can be disabled at some times so you cannot see it, or Autoplay only displays a view picture 'icon' when there is/are picture/s on your 2gb sandisk sd card.To manually view your pictures, you can follow this steps:1. Head on to your computer by clicking Computer on the Start Menu.2. From there you can see an sd card icon that displays your inserted 2gb sandisk sd card name.3. Click that icon, then from there you can see and browse the files on your 2gb sandisk sd card, including your pictures.Click Helpful if this fix your problem :) It would be a pleasure.Further questions? Comment below! It will be entertained. :)
SD and micro SD cards have a small slide switch on the edge of the card to protect the data stored on the card. To unlock the write protection move the slide switch to the write position.
Hi, Since I was facing the problem when I connected my memory card to the system and accidentally deleted my photos in memory card and came across the recovery software to recover data from memory card and here is download link
You may try asoftech data recovery which helped me before. You can download trial for freehttp://www.asoftech.com/adr/Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Open My Computer after inserting the drive into a USB port on your computer. Right-click on the drive and select Properties. You should get a nice chart with the used and free space!
