20 Most Recent Rowenta Commercial Garment Steamer - White Questions & Answers
10answers
MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
8/30/2021 6:24:25 AM • Rowenta... • Answered on Aug 30, 2021
2answers
My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
1/14/2019 9:06:26 AM • Rowenta... • Answered on Jan 14, 2019
Clothes steamer won't steam home touch
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
5/8/2018 6:27:08 AM • Rowenta... • Answered on May 08, 2018
2answers
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose. Another reason could be that you are using too much steam for that particular fabric.
1/5/2018 5:54:24 AM • Rowenta... • Answered on Jan 05, 2018
Replacement parts
Check this site out Terry,if not their let me know. Rowenta IS8100U1 A6 Steam Brush Parts
7/7/2017 9:40:56 PM • Rowenta... • Answered on Jul 07, 2017
0answers
NOT TURNING ON
Be the first to answer 5/12/2017 12:45:03 AM • Rowenta... • Posted on May 12, 2017Be the first to answer
How do I get the wheels off?
Just pop it off. Need force, no need to take hub caps off.
6/30/2016 7:39:56 AM • Rowenta... • Answered on Jun 30, 2016
How to open is 9050 rowenta precision valet to descale
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
4/15/2016 6:37:25 AM • Rowenta... • Answered on Apr 15, 2016
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
11/16/2015 4:58:06 PM • Rowenta... • Answered on Nov 16, 2015
Can I put diluted disinfectant in the water cannister?
Unless it smells bad I wouldn't. Just always use distilled water. The unit is boiling the water so what comes out is already disinfected.
7/1/2015 8:58:58 PM • Rowenta... • Answered on Jul 01, 2015
2answers
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
4/24/2015 3:43:39 AM • Rowenta... • Answered on Apr 24, 2015
2answers
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
2/3/2015 8:21:57 PM • Rowenta... • Answered on Feb 03, 2015
Rowenta 1500 watt steamer just keeps beeping when you turn it on and then turns itself off, does not produce steam. What should I do?
Clogged unit, it's over heating. Run vinegar through it to remove deposits.
9/8/2014 3:23:13 AM • Rowenta... • Answered on Sep 08, 2014
How to clean a Rowenta steamer
WHen cold tilt over sink and empty and rince every 3-5 uses depending on how much you use it. Water sitting in the tank gets moldy and bad, rinse tank and use Britta type filtered water only.
9/7/2014 4:37:44 PM • Rowenta... • Answered on Sep 07, 2014
Were can i take my rowenta steamer for repair in the 90035 los angeles area
Anaheim, Berkley, Fresno, Bakersfield, Los Angeles, Long Beach, Sacramento, San Diego, San Jose and San Francisco. Google Rowenta repair Center, choose a city and go!
9/7/2014 4:01:59 PM • Rowenta... • Answered on Sep 07, 2014
Rowenta Commercial Garment Steamer - White Logo
238 questions posted
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
rowenta 1550w upright steamer no longer
  • Irons
