20 Most Recent
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Questions & Answers
Suds then f35
Whirlpool Duet 4.0 Cu. Ft. 14-Cycle
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Install shipping bolts
This will not be necessary if the machine is transported on its back lay it down carefully on its back should not be a problem
Water does not come out
Try removing the panel at the bottom and removing the sump dial by turning it counter-clockwise with a pair of channnel locks. Remove the sump tray and clean out, then reinstall and test.
My whirlpool duet steam model # wfw97hexw....it has a sold front cabinet with no access door to clean the filter trap...other machines have an access door near the bottom, mine DOES NOT...so, how do i
I believe you can accomplish this buy going in from back of machine. Be careful of sharp edges, and unplug power. Remove rear panel screws top, bottom, side and side ,you may need to remove hoses. When your in, the pump is at front, and sits on rubber mounts that slide into their metal housings. You will need to disconnect hoses on each side and push the pump forward or backward you will see this when your in there. Remove pump, unscrew filter, check inside impeller area, and check both hoses each way. You would be surprised what kind of stuff gets through. GOOD LUK FRIEND.
Can I put baking soda in my whirlpool front load washer to wash new sheets?
Hi Ursula B,
You can put baking soda in your washer safely with no harmful effects.
Another good use in your front loader for baking soda.put 1/2 cup of vinegar in your washer soap dispenser,and 2 or 3 tablespoons of baking soda in the fabric softner dispenser and run a hot wash to clean and refresh your washer.
Message sud and f35 causing washer to stop washing
don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
F35 ERROR IN DIAGNOSTIC TEST C:00
I have been
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
