20 Most Recent Ducane 30400040 Stainless Steel Grill Questions & Answers
2answers
The gas in no pasing to the burnes
This happened to my grill too. I had to replace the stainless steel tube burners- only 1 was broken but I replaced all while inside. Parts are available at various sources online and this is easy to fix. You will need to open the front panel. If you have a helper to hold it, that will make it easier and you won't detach the internal wiring.
9/18/2021 8:09:03 AM • Ducane 30400040... • Answered on Sep 18, 2021
Replace a ducane grill tube
5/3/2019 1:53:49 AM • Ducane 30400040... • Answered on May 03, 2019
I changed the gas tank, with two different ones to be sure it wasn't the tank. The ignitor parts but there does not seem to be gas getting to the burners.
It is possible you are just turning the gas valve on the tank too fast, causing the excess flow valve in the line to "check" or close. Disconnect the hose from the tank and then reconnect it. Then slowly open the tank valve and see if that solves your problem.
6/16/2015 3:35:48 AM • Ducane 30400040... • Answered on Jun 16, 2015
0answers
0answers
0answers
Orifice
Be the first to answer 5/31/2013 12:17:37 PM • Ducane 30400040... • Posted on May 31, 2013Be the first to answer
Grill doesn't heat to high temperature.
try cleaning the injectors they could be blocked
8/25/2012 12:45:45 AM • Ducane 30400040... • Answered on Aug 25, 2012
Replacing igniter on 30400042-30400043
Go here:http://www.appliancefactoryparts.com/gasgrillparts/brands/ducane/30400042.html#Igniters
7/18/2012 7:11:42 PM • Ducane 30400040... • Answered on Jul 18, 2012
Ducane 30400040 Stainless Steel Grill Logo
124 questions posted
Top Ducane Grilling Experts
Paul Carew
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
View Most Popular
Ducane Grilling
  • Ducane Grilling
Most Popular Question
three main burner
  • Grilling
