20 Most Recent
Dodge 2008 Grand Caravan SE Questions & Answers
TOUCH SCREEN DON'T WORK
Only one thing in common, power. Your power source became disconnected is my guess. Could something se but try that first
1994 dodge spirit. Shifted cable
The shift cable on a 1994 Dodge Spirit connects the gear shift lever to the transmission, allowing the driver to shift gears. If the cable is damaged or worn out, it may need to be replaced. Here are the general steps to change the shift cable on a 1994 Dodge Spirit:
- Park the car on a level surface and set the parking brake.
- Locate the shift cable where it connects to the transmission. It will be on the driver's side of the vehicle, near the front of the transmission.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the transmission.
- Trace the cable up to the gear shift lever inside the vehicle.
- Remove any trim pieces or panels that are blocking access to the cable connection at the gear shift lever.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the gear shift lever.
- Remove the old shift cable from the vehicle.
- Install the new shift cable by first attaching it to the gear shift lever and then connecting it to the transmission.
- Secure the cable to the gear shift lever and transmission using the retaining clip or nut that you removed earlier.
- Test the new shift cable by shifting through all of the gears to ensure that it is functioning properly.
- Replace any trim pieces or panels that you removed earlier.
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
