20 Most Recent
Krups FBC412 1600 Watts Toaster Oven with Convection Cooking Questions & Answers
Setting time
I own the exact same toaster oven. Can't locate the manual. Also,
tried to set the time,which was off by 2 hours,and no luck,either.
Try to Google the instruction manual pdf. Good luck.
Our FBC412 just won't power up. Is it worth
Hi. you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck
My krups stop working while
Make sure you have AC at the wall-plug by plugging in another appliance there. If not, you may have a tripped GFI (Ground Fault Interrupter).
If power is there, a thermal fuse, now common in many 'hot' appliances, may have failed.
These are almost all made in China now and have proven very unreliable; you may just be another victim of this.
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
