20 Most Recent Frigidaire Affinity ATF8000FS Questions & Answers
2answers
The door on my fridgidaire atf8000fs1 sags so it
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem. After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time. i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
2/7/2019 7:43:45 AM • Frigidaire... • Answered on Feb 07, 2019
Affinity ATF8000FS front load not
Are you using HE soap?
6/11/2017 5:11:53 AM • Frigidaire... • Answered on Jun 11, 2017
My atf8000fsi washer keeps pausing. It will not
EF2 on a Frigidaire washing machine indicates too much soap which could mean the pressure chamber is blocked or the pressure switch is held closed for some other reason. Try removing the small bore hose from the pressure switch and listen for a click when you do so, if there is a click it will indicate you have a pressure chamber blockage. The chamber will need to be removed and cleaned out don't just blow into it via the attached hose because it will block again after a few washes
3/29/2017 1:23:30 PM • Frigidaire... • Answered on Mar 29, 2017
0answers
Affinity ATF8000FS won't drain
PLUGGED PUMP OR HOSE LINES?
3/31/2015 10:38:41 PM • Frigidaire... • Answered on Mar 31, 2015
How do I remove detergent tray?
Good Afternoon friend, thank you for your post! From the information you have provided you need assistance removing the detergent tray from your Frigidaire washer, ATF8000FS. In order to remove the tray you should be able to push down on the push arrow and pull the out on the drawer. It should slide right out. If you have any troubles please feel free to reconnect. -Matt
3/17/2015 8:56:31 PM • Frigidaire... • Answered on Mar 17, 2015
ATF8000FS1 washer is stuck in pause. Any suggestions?
Hi friend, thanks for your inquiry!
If your washer continues to display an error code of "PAU" it could be an issue with your door lock but if the door strike is not sitting properly within the latch your washer will continue to provide the error code "PAU". Additionally, if your control panel is registering that the door is closed you may continue to experience the "PAU" code. I would recommend having a professional come and properly diagnosis your washer to prevent any unnecessary part purchases. I hope this is helpful. -OOS
10/15/2014 6:46:45 PM • Frigidaire... • Answered on Oct 15, 2014
Fridgidaire affinity washer Pau lights every time hit start
Did you check to see if the water outlet valves (that connect to the washer) are Good, Turned On and water comes out? Anyway you are not getting water into the machine either from that or you have 2 (Hot and Cold) water inlet valves are bad (very rare for both to fail). The fault code is usually "PU", not PAU! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
7/26/2014 8:18:02 AM • Frigidaire... • Answered on Jul 26, 2014
What is e70
Good Morning Ronald, thank you for allowing me to assist you! Typically error code E70 indicates that the hoses on your washer may possibly be reversed. This causes your washer to think the water temperatures are incorrect. I recommend checking the hoses and make sure they are located on the correct valve and faucet. Also confirm that there aren't any restrictions or kinks in the drain hose. I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Best of luck!
2/4/2014 4:26:33 PM • Frigidaire... • Answered on Feb 04, 2014
After the wash is finished in my frigidaire affinity ATF8000FS, I noticed that the fabric softener remained in the dispenser. ????
You will need to open the dispenser and clear the internal channels out.There is a service manual available that shows you how the internal dispenser works if you should need it.
2/18/2013 3:20:06 AM • Frigidaire... • Answered on Feb 18, 2013
Only button that "beeps" is cancel
If the buttons works but not the beep , then it can be related to some error in the program or a switch off/mute.However if the buttons do not work then it can be moisture build up within that can cancel the switching and so there is no beep as the contact is not made. In any case try and heat the front panel very softly and see if the fault clears.
1/25/2013 6:12:23 AM • Frigidaire... • Answered on Jan 25, 2013
This machine was spinning with an uneven
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound1 time and "rES" will be shown briefly in the display.2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,the buzzer will sound 3 times and all LED's will rapidly flash.After entering the test mode, the cycle selector knob can now be rotated to select the following tests:Rotate the cycle selector knob clockwise from the starting position:0 turns: All LED's will flash.1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggleback and forth in the display.2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in thedisplay showing moisture sensor readings. Opening the door (press in on door switch plunger) and placinga finger on the both moisture sense bars at the same time will make the numbers decrease. In controls thatdo not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switchplunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LEDcome on.4 turns: Drive motor runs; heat source is off.Key test:a. When the Temperature key is pressed, all the temperature LED's should light.b. When the Dryness key is pressed, all the dryness level LED's should light.c. When the Options or Select key is pressed, all the Option LED's should light.d. When the Start/Pause key is pressed, all the cycle status LED's should light.e. When the Cancel key is pressed, all the cycle status LED's should light.5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.7-11 turns: All LED's will flashTo EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect powerfrom dryer. Dryer will be reset for regular operation.If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
11/11/2012 8:33:36 PM • Frigidaire... • Answered on Nov 11, 2012
Frigidaire Affinity ATF8000FS Logo
58 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
after wash finished in frigidaire
  • Washing Machines
