20 Most Recent Samsung SP43J6HD 43" Television Questions & Answers
Working fine, then loud squeal and some smoke, picture was still
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
4/29/2017 3:26:35 AM • Samsung SP43J6HD... • Answered on Apr 29, 2017
0answers
Be the first to answer 4/11/2014 6:30:45 PM • Samsung SP43J6HD... • Posted on Apr 11, 2014Be the first to answer
Reset lamp samsung sp43j6hd
The quick way if it even has this feature is to call customer service for Samsung or look for the service manual online by model number.
12/18/2012 9:14:04 PM • Samsung SP43J6HD... • Answered on Dec 18, 2012
0answers
2answers
I have just bought a new lamp for my samsung
If you have replaced the Lamp and TV Fails to work, then you also need to check the Fans and make sure they are OK. If Fans are OK then Repalce the Ballast Board.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368 Ballast Board is what powers Lamp ON.
2/7/2011 5:51:06 PM • Samsung SP43J6HD... • Answered on Feb 07, 2011
I have a samsung tv model s6-43w6hd and i need a
The best price for a lamp to the Samsung SP43J6HD is $75.88 at http://www.amazon.com/Electrified-BP96-00826A-BP96-00608A-BP96-00837A-Replacement/dp/B003QL370U/ref=sr_1_2?s=electronics&ie=UTF8&qid=1294330442&sr=1-2 I hope this will help...
1/6/2011 4:20:31 PM • Samsung SP43J6HD... • Answered on Jan 06, 2011
Red outline shadows on the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:49:11 AM • Samsung SP43J6HD... • Answered on Jul 03, 2010
Hi guys I would like to know how old the SP43W6HL
Look in the back for manufacture date.But as i remenber these set are mostly produced in the years of 2001-2005 the high light of these tvs models.My best estamate as used and good conditon tv.Max price u could get for it about $800 max.
6/10/2010 5:32:42 AM • Samsung SP43J6HD... • Answered on Jun 10, 2010
How can I recieve hd channels i have just had a hd
the cable or satellite box should also have a component input which is the red,white,red,blue and green cables.these will also provide hd quality
5/19/2010 8:50:33 PM • Samsung SP43J6HD... • Answered on May 19, 2010
The tv switches on and the screen comes on, but
That is not entirely true. This is not an incandescent lamp, it is a gas filled lamp. When it is about to go out, which includes exploding, the resistance will drop which means the lamp will pull more current. The ballast will sense this and shut down the TV. You need to replace the lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix the unit and where to get the parts. Let me know if you need more help.
Thanks for using FixYa.
hardrocko
5/13/2010 7:31:28 PM • Samsung SP43J6HD... • Answered on May 13, 2010
My Samsung SP43H3HT TV IS BLURRED AND HAS
Convergence issue. Repair shop. Call for an estimate.
3/22/2010 7:28:43 PM • Samsung SP43J6HD... • Answered on Mar 22, 2010
Showing ghost image on right hand side
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2/2/2010 9:26:28 PM • Samsung SP43J6HD... • Answered on Feb 02, 2010
My Samsung SP43H3HT picture is blured in parts and
It sounds like your convergence STK IC chips have gone bad. They need to be replaced. Good luck!
11/7/2009 11:33:58 AM • Samsung SP43J6HD... • Answered on Nov 07, 2009
The screen piture will not appear,
In this case is best if you replace it, but first, try identifying any awkward noises, if it's clikcing the issue is with the ballast, if it's humming, it's with the color wheel, and if you replaced the lamp already, it's most probable that the issue would be either ballast or colorwheel
8/6/2009 7:47:09 PM • Samsung SP43J6HD... • Answered on Aug 06, 2009
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/17/2024 5:31:49 PM • Samsung... • Answered 21 hours ago
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered 3 days ago
Samsung plasma tv repair PN51F5300BFXZA
All I can advise is to take it to an authorised Samsung repair shop. A list is available on the Samsung web site.
4/7/2024 8:20:50 AM • Samsung... • Answered on Apr 07, 2024
Samsung SP43J6HD 43" Television Logo
Popular Tags
25 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
showing ghost image right hand side
  • Televison & Video
