20 Most Recent HP M2727NF Laserjet Printer Questions & Answers
How should I solve the problem of hp laser jet M2727nf when shows error message "Scanner error 5 and turn off then on?
The "Scanner error 5" is a notorious problem on the HP LaserJet M2727mfp series printers. ... The "Scanner error 5" usually triggers when the scanner's drive motor fails. Fortunately, replacing the scanner assembly (which includes the motor) is not considered difficult.
2/23/2022 5:06:26 PM • HP M2727NF... • Answered on Feb 23, 2022
Way printing blank in hp 2727nf
Hello ,It seems 1 Your shutter lock may be damaged.(laser shutter)2 tooner may be empty.jm
6/19/2017 11:16:06 AM • HP M2727NF... • Answered on Jun 19, 2017
Where do I load legal size paper 8.5 by 14 to print on my m2727nf
The tray should extend to the 14" length size, pull the tray all the way out and look for the unlock (green) lever...Extend the tray to the proper size and then install the paper. You will most likely need to go to your paper size settings in the menu of the printer and tell the machine that you changed the tray to 8.5 x 14...usually under paper tray settings. If you do not have a way to extend the tray then you do not have the option to run 8.5 x 14 paper and an optional tray will need to be purchased, or the bypass tray can be used but only 10-15 sheets at a time. Hope this helps
12/22/2014 7:08:30 PM • HP M2727NF... • Answered on Dec 22, 2014
0answers
M2727 MFP no lights on the display
probably a cable is loose or not connected for display. printer could be faulty or you mught fix easily.
2/6/2014 7:27:55 AM • HP M2727NF... • Answered on Feb 06, 2014
Remove fuser
I hope you already found the answer to this but if not here is a link to the service manual. fuser removal starts on page 147. http://www.feedroller.com/store/Service%20Manual/HP-LJ-M2727-MFP-Manual.pdf Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
12/12/2013 8:09:10 PM • HP M2727NF... • Answered on Dec 12, 2013
2answers
M2727 goes to sleep after a day or so and cannot
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
12/12/2013 7:59:50 PM • HP M2727NF... • Answered on Dec 12, 2013
2answers
No display on hp laser
Does the printer otherwise print? If so, then the panel is dead.
12/12/2013 7:52:21 PM • HP M2727NF... • Answered on Dec 12, 2013
2answers
HP m 2727nf randomly shatsdown
Something is gone on the unit and most likely getting hot or is out of sink. Laser products eventually wear out because they use heat to do the work they were made to perform. If nothing seems out of sink this happens "out of the blue" so to speak, it time for a replacement.
5/25/2013 11:26:49 AM • HP M2727NF... • Answered on May 25, 2013
2answers
Laser M2727 making lines on copies. The glass is
Clean a feeder or replace one or more damaged light diods.
8/5/2012 11:36:56 AM • HP M2727NF... • Answered on Aug 05, 2012
2answers
My HP 2727nf ADF gets stuck on the second page
First, make sure that the firmware is up to date on the machine. Current revison is 20100902. Download from www.hp.com. That may not fix the problem, actually probably won't but can't hurt to try. I have found that this problem is usually caused by a bad ADF cable or board. Either way, unless you have a donor machine you will need to purchase a new ADF assembly. Part number is CB532-67903.
12/20/2011 4:19:28 AM • HP M2727NF... • Answered on Dec 20, 2011
I have a M2727NF printer and it tells me to order
keep working until it stops and then place the new one.
some printers will not know how much toner is left after the warning, so at one moment it can just start printing light in vertical lines, this means the toner is near empty (but you can shake the cartridge slight, to get some more pages, if you dont have new cart. at hand).
so keep printing and dont worry
9/18/2011 8:52:39 PM • HP M2727NF... • Answered on Sep 18, 2011
Hp m 2727 mfp says replace cartridge but it is new
If it's a new cartridge, return it.
It is probably defective.
HP guarantees their cartridges.
6/10/2011 5:50:15 AM • HP M2727NF... • Answered on Jun 10, 2011
HP M2727NF Laserjet Printer Logo
72 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
m2727 goes sleep after day or cannot
  • Office Equipment & Supplies
