20 Most Recent Acer TravelMate 3260-4542 Notebook Questions & Answers
2answers
Enable/Disable Bluetooth switch not working. Way to disable bluetooth other than switch by indicator light?
try with battery out & restart pc or reset setings=default options
3/31/2015 4:59:06 AM • Acer TravelMate... • Answered on Mar 31, 2015
I want camera driver for this model Acer TravelMate 3260AWXMi
Go to http://support.acer.com/product/default.aspx?modelId=216 Choose OS, download, unzip, and run setup.
10/12/2012 11:09:12 AM • Acer TravelMate... • Answered on Oct 12, 2012
TravelMate 3260-4542 ......getting message that
It sounds like the battery may be going bad, not holding a charge anymore, or the processor may be overheating and shutting itself down as a precaution. Some BIOS may have a temp reading if you enter the bios at boot up, usually by pressing del key or F1 key, it should tell you at reboot, right at the first second or two after power is turned on "press del key to enter setup" or something similar.
If your BIOS does not have a temp readout, you can download freeware temp reading tools from cnet.com.
Make sure that your fan is blowing out the port in the back and that it is not obstructed by something.
If it is none of these, you may have a virus, In which case, try the following:
While the system is booting --before the xp2_bing.gif logo shows, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The os will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont run normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot2_bing.gif. If it still won't run right, you may want to reinstall the OS and see if that works. If reinstalling the OS after formating the drive doesn't fix it, it is definitely a hardware problem. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
4/23/2010 7:31:48 PM • Acer TravelMate... • Answered on Apr 23, 2010
No audio device
The audio driver is available from this link http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
download and instal the driver -
Have a look in device manager and see if you have an audio device Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc - look for sound devices, click on the + sign make sure a sound device is listed
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
3/31/2010 2:03:33 PM • Acer TravelMate... • Answered on Mar 31, 2010
2answers
Camera installer for acer travelmate 3260awxmi ive
Get at the Acer support site.
3/16/2010 3:39:46 PM • Acer TravelMate... • Answered on Mar 16, 2010
3answers
Internet connection
if you bought the computer new and got a recovery disk it can reinstall drivers from recovery disk if not ur best option would be to get a recovery disk for ur type of windows
11/11/2008 5:08:52 AM • Acer TravelMate... • Answered on Nov 11, 2008
Useing note book with data projector
connect through the vga port of the laptop, then press Fn key and the key mark monitor on your laptop, F5 together
11/3/2008 9:37:42 PM • Acer TravelMate... • Answered on Nov 03, 2008
SONY uvw 1800 Error Code 02-454
The unit powers on, the drum shows only 0005 hours on it, but the display says it has an "Error 02-454" Error Code, and says "REC Inhibit", and it will not accept a tape. When this unit is powered on it shows error code 02-454 which is:
S-REEL FG COULD NOT BE DETECTED WHILE IN FF/REW MODE.
You can cross-reference this error code at the following web site:
http://www.johnjvsvisual.pwp.blueyonder.co.uk/UVW1600-1800%20error%20codes.pdf
From what I’ve been told this is a very easy fix for someone that knows how to work on these. It is a very clean machine, inside and out, and I am sure it is well worth getting serviced and put back in use
8/2/2008 1:48:33 PM • Acer TravelMate... • Answered on Aug 02, 2008
2answers
How do I get my laptop to play dvds again it won t work
When you say play DVDs you mean watch DVD movies? Assuming the drive is not broken you need to use the DVD app. You could use VLC Player which you can download. It's an orange traffic cone icon.
9/18/2021 11:29:44 AM • Acer TravelMate... • Answered on Sep 18, 2021
How to fix the black screen on acer travelmate5620 even on the external monitor its doesn't show
Could be it has overheated and the NVidea chip is damaged. No idea why they are called laptops as to put them on a lap blocks the ventilation and they will overheat.
7/20/2021 3:06:30 PM • Acer TravelMate... • Answered on Jul 20, 2021
2answers
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
8/22/2017 5:28:34 AM • Acer TravelMate... • Answered on Aug 22, 2017
2answers
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it. You can install Facebook on it by going to the "Microsoft Store". If it didn't install, check if your operating system is 8.1 Let me know if that helps.
1/31/2017 8:11:05 AM • Acer TravelMate... • Answered on Jan 31, 2017
Acer TravelMate 3260-4542 Notebook Logo
11 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
TravelMate Acer
  • TravelMate Acer
Most Popular Question
travelmate 3260 4542 getting
  • Computers & Internet
