20 Most Recent
Frigidaire FWSB5700DS Top Load Washer Questions & Answers
I have a frigidaire fwsb34rgs0 top loading
Hello I have same washing machine & when it starts to spin small black dirt is coming from inside. Tried cleaning it couple of times & also check water hose. When the water gets in the drum water is clean but when it starts rotating black particles come. Not sure of the issue.. can someone share the manual of this washing machine basically to know its Cu ft. Any idea of its capacity & what model replaces it in form factor as the dryer is working fine.
Thanks
Pras
What is the drum size of the washer?
Hello Friend, that's a great question!
In order to provide you the correct drum size of your Frigidaire washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front as you open the door if you have a front load washer. If you own a top load washer, you may find the serial tag inside the lid, on the right side. Thank you and I look forward to your response.
Will agitate won't spin
Good Afternoon Friend,
I understand your Frigidaire washer, model# FWSB5700DS, will agitate but not spin. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is returned, select any cycle and run the wash. If you are still noticing that it is agitating and not spinning, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it will agitate but not spin. Hope this is helpful.
-Best Regards-
WP
Washer doesnt spin
Possible that the program controller unit is the suspect as it does not switch and provide the voltage for the spin cycle.
