During normal operation, the display may show:
“SAn” - deep clean (Sanitary Cycle)
“cd” - cool down (Sanitary cycle)
“do” or “dr” - door problem.
“Err” - an error has been detected.
“LOC” - control lock is activated.
“PAU” - cycle has been interrupted.
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin
Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the
LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and
Start/Pause buttons until LEDs start sequentially
chasing, then release buttons.
Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal
operation.
a) Unplug the power cord, wait 5-8 seconds, then
reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks
after the Start Position. Press Options and
Start/Pause buttons together for a few seconds
until wash cycle LEDs appear.
Simple right? LOL and then you do the hokey pokey...
OK where where we?
Ah yes we needed to dump the old code so we can do a fresh
diagnostic Test.
Diagnostic Test:
The diagnostic test is used to check individual component
function only.
TO START THE TEST:
Spin Only.
• Press Cancel to stop the cycle and turn off the LEDs.
• Within 5 seconds, press and hold the Options and
1. All the LEDs will sequentially light. Pressing a
button below a light cluster will light all the LEDs in
that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent
compartment.
3. Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach
compartment.
4. Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
5. Turn the program knob (4) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.When the door is
opened, the drum light should turn on.
6. Turn the program knob (5) clicks from the start
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
7. Turn the program knob (6) clicks from the start
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
SAFETYWARNING: If power is removed during this
test, the door can be opened. To prevent injury, DO
NOT put your hands inside when the tub is rotating. Oopz!
8. Turn the program knob (7) clicks from the start
position. The control will signal the last error code.
Exiting Diagnostic Mode
There are two options for exiting theDiagnosticTestmode
and returning the washer to normal operation:
b) Turn the program knob clockwise 2 or 3 clicks after
the start position. Press Options and Start/Pause
buttons together for a few seconds until wash cycle
LEDs appear.
If a situation arises where you cannot exit the
Diagnostic mode as described above and the
bank of 5 LED’s on the right end remain ON
regardless of Program Knob position, a combination
of pushed buttons may have caused the
control to enter a special factory test mode.
Disconnect power to reset the control to return
washer to normal operation if this occurs. Are we clear so far? It gets better: Here are your fault codes:
E11 Fill time to long check inlet screens, kinked
hoses unpaid water bill Etc
E13 Water leak in tub or air leak in air bell or
sediment in hos as well. Blow that ****** out.
E21 Water not pumping out fast enough. trash i pump,
frozen drain call roto rooter, skip that LOL
E23 Drain pump relay on control board failed, check
for broken wire or buy a new board hay you could use a
$500 spare right?
E24 same as E23
E31 Pressure sensor not communicating with control
board find tube blow out sand sediment etc
E35 Again sediment or suds in tube.these type errors
can be caused by too much soap wrong soap soap placed
in wrong dispenser.
The rest are on page
63
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
