20 Most Recent
Panasonic Viera TX-32LX70 32 in. LCD TV Questions & Answers
How do I get free time tv
the easy way is just google your tv how to do this set up is found on you tube you google search your tv then free view re-tune on you tube then scroll down to it.
I want to know the service menu code of Panasonic TX-32LX70C
If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful.
Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
My Panasonic Viera TV is stuck on one channel and
Hi Geric1,
Reset your unit to factory settings. Follow this instructions :
1. On your remote control press the "menu" key.
2. Press the "right" key >.
3. Select "set-up" by pressing the "down" (v) key. Then press "OK" key.
4. Select "shipping condition" by pressing the "down" (v) key. Then press "OK" key.
After this go to menu again then select the set-up but this time access the tuning menu and then auto set-up to set all channels available in your area.
Your done, Exit to. Checked if the unit restore factory settings.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Code for TX-L37E3B
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window" to get gathered related posts.
Need code for chunghop RM 101 universal remote.thx
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
No dvb signal found, please click ok to tune. Tune then does not work and no channels.
If you have another TV fed from the same antenna, I assume you have a splitter/distribution amplifier because you know you cannot just join two cables together don't you?
It is more than likely the splitter/amplifier, cable or connections rather than the TV but to make sure you must move the TV in the other room and try it on the suspect cable before condemning the TV.
Signal problems are usually due to water ingress and this could have happened on just one cable.
Failing that, the TV input could have failed. It is not common but does happen now and then.
