20 Most Recent
Polaroid PDX-0073S Portable DVD Player Questions & Answers
My Polaroid DVD player has been used very little.
Sounds as if the EYE is dirty. Look closely at the spindle (cd mounts on) and try to locate the glass eye. Swab with alcohol gently, I mean gently.
If still bad, then the eye transport mechanism needs to be replaced. Not hard couple of screws and flex cable, look for part number and then go to matelectronics.com good luck, be safe..
4/25/2009 12:28:13 PM •
Polaroid...
Answered
on Apr 25, 2009
I need a new battery
go to the link for purchase--
http://www.google.com/products?client=opera&rls=en&q=purchase+dvd+bt-0710+battery&sourceid=opera&ie=UTF-8&oe=utf-8&um=1&sa=X&oi=product_result_group&resnum=1&ct=title
11/12/2008 7:56:38 PM •
Polaroid...
Answered
on Nov 12, 2008
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
How do I switch my Polaroid P40LED13 TV on to AV mode. No option in sources
If you are using the standard SNES cables with the round red, white and yellow 'Jack' plug connectors they are referred to as "Component" connections. On your remote there should be a button marked "COMP". It will probably be near the top of the remote near the Power button. This should switch the TV to the channel you need.
3/27/2023 9:22:04 PM •
Polaroid...
Answered
on Mar 27, 2023
