20 Most Recent Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Questions & Answers
0answers
40rl858
Be the first to answer 2/5/2018 2:39:03 AM • Sagem PVR 6280... • Posted on Feb 05, 2018Be the first to answer
My box sagem pvr 6240 stop suddenly and started to flashing er09
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
9/7/2017 8:52:50 AM • Sagem PVR 6280... • Answered on Sep 07, 2017
Hi. When switch on there is no clock lit up on front and does not switch on. Can hear fan working. Tested 12 v adaptor and no issues.
When you say that you have tested the 12V adapter, have you checked it under load? This is the most likely cause of the problem, so I suggest trying another suitably rated adapter.
4/28/2015 7:47:21 AM • Sagem PVR 6280... • Answered on Apr 28, 2015
Why is my sagem recoder keeps cutting off, what is wrong with it.
It probably needs some capacitors replacing in the the power supply unit (PSU).
7/13/2014 7:28:20 PM • Sagem PVR 6280... • Answered on Jul 13, 2014
Tv receiver does not record after 12pm
Do you have some power-saving device that operates at midnight?
3/20/2014 10:02:01 AM • Sagem PVR 6280... • Answered on Mar 20, 2014
PVR says HDD not detected.
Disk may have failed or become corrupted. If it's a few years old, its PSU capacitors are probably failing. This is repairable, but you may lose your recordings.
3/20/2014 9:33:38 AM • Sagem PVR 6280... • Answered on Mar 20, 2014
Used 12v power supply and only get a yellow flashing light
If you used the wrong power supply, it has probably blown an internal regulator in the Sagem. It may be fixable by a someone who can solder a new component in for you.
3/20/2014 9:17:44 AM • Sagem PVR 6280... • Answered on Mar 20, 2014
2answers
I have installed A Sagem DTR67250T 250gb with the
I am also getting his p603 error on my DTR67250T. I saw on another site that it indicates a problem with the power supply and should contact Sagem Technical Support on 0845 0900316 to get a new one - said it would be 10.
1/6/2014 10:02:31 PM • Sagem PVR 6280... • Answered on Jan 06, 2014
0answers
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
222 questions posted
Popular Products
Top Sagem Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sagem Televison & Video
Most Popular Question
no tv guide showing record
  • Televison & Video
