20 Most Recent
Frigidaire FEF336BC Electric Kitchen Range Questions & Answers
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Frigidaire Smooth Top Range/Oven stopped working
for all others with this problem: I had the stove serviced. Repairman reported a loose wire to the elemets (tightened and did not fix the problem) followed by a stuck relay, and after some banging on the back of the control panel, the elements now work fine. He said if it happened again the only solution would be to replace the relay/control panel, a part of about $160, but I'll get credit for the price of the service call already paid. Compare to the price of the stove, I'll accept the $125 for the service call.
so tapping on the back of the control panel is worth a try if your stove is pulling this trick.
Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Binking light on one control of electric blanket (Sunbeam)
I'm not sure how I was registered as having a problem with an electric range; my problem was with my Sunbeam electric mattress pad.
I used one of the suggestions I read here. I unplugged the connection to the mattress pad and blew into the receptacle to clear any dust or lint from it. I reconnected everything, plugged it in, and the problem has been eliminated.
Thanks for the suggestion.
Why doesn't my stove top and oven heat up
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
I got the Oven door unlocked but...
Not sure what f-15 is either? Look on the back of the stove and see if there is a tech sheet. This will tell you the codes. My guess would be the lock motor has gone bad. You can check the motor by removing the wires from its terminals and check for resistance with an ohm meter. Make sure to unplug stove first! Was this after running a clean cycle? Let me know what you find.
10/14/2014 12:38:37 PM •
Frigidaire...
Answered
on Oct 14, 2014
