20 Most Recent
Kodak Easyshare C813 Digital Camera Questions & Answers
My Kodak EasyShare C813 says lens error 111000
Fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Hi i have a kodak
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Kodak problems
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Why will my C813 suddenly no longer load pics to my computer?
If you insist on connecting your camera to your computer, what program(s) are you using for the download? What operating system do you have on your computer? If you're getting an error message, what does it say?
Unrecognised file format. How can
Do not take any more pictures, and remove the card from the camera to lessen the chance of you overwriting some important pictures or videos. There are very many freeware software options available to help you recover your files. Please
see this article that reviews several of the better freeware recovery programs that you can try (and yes, these truly are freeware). You may need to use a card reader with these programs though.
AFTER you've recovered the photos, format the card in the camera using the camera's format feature to prevent this from happening again.
My DCIM folder is showing
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This blog article reviews and outlines several of the better ones.
