20 Most Recent Casio Parts Cash Register PC Desktop Questions & Answers
2answers
How do i reset my grand sales on a casio TE 2000
very simple solution with no reprogramming of the unit. - in Z mode: make a report and read the grand total sales amount - in RF mode make a refund of that amount - in Z mode make a report again to check that the grand sales is zero.
2/12/2024 9:15:54 AM • Casio Parts Cash... • Answered on Feb 12, 2024
2answers
My Casio cash register is frozen. If I press any
Which model number do you have?
11/15/2023 4:41:56 PM • Casio Parts Cash... • Answered on Nov 15, 2023
IBM Toshiba SurePOS 4852-580 15 , cash register.
If an IBM Toshiba SurePOS 4852-580 15 cash register that you purchased used is not allowing you to make any changes and says "unauthorized," there could be a few possible causes:
  1. The cash register may be locked by a previous owner: The cash register may have been locked by the previous owner with a supervisor password. You will need to obtain the password to make changes.
  2. The software may be outdated: The software may be out of date and require an update. You will need to contact IBM for assistance with this.
  3. The system may have been tampered with: The cash register may have been tampered with, which could have caused the system to become locked and require a service technician to reset it.
  4. The cash register may have a security feature enabled: Some IBM Toshiba SurePOS have a security feature that allows only authorized users to make changes. You will need to contact IBM for assistance with this.
  5. The cash register may have an issue on the hardware: some issue on the hardware of the device could be preventing the device from functioning properly.
4/16/2023 3:28:45 PM • Casio Parts Cash... • Answered on Apr 16, 2023
Casio TK-2300 Service Manual
There isn't one available. User Manual and Programming Manual only. There are sites that SAY they have it but don't. This search query forces results that mention this model. https://www.google.com/search?q=Casio+%22TK-2300%22+Service+Manual ..
11/11/2022 1:33:47 PM • Casio Parts Cash... • Answered on Nov 11, 2022
Casio ce6000 error code e004
That means it is having trouble with the memory backup. Don't unplug the machine as it is about to lose all programming and sales data. Has this machine been turned off for a long period of time? When was the battery last replaced?
9/8/2022 5:52:46 PM • Casio Parts Cash... • Answered on Sep 08, 2022
2answers
I have a tec ma 1350 cash register and slip price keeps popping up whats wrong
Had the same problem if the slip price light is on blow out the validation slot with a can of air its that simple
8/9/2022 2:20:29 PM • Casio Parts Cash... • Answered on Aug 09, 2022
I have a casio se g1 im trying to program it in rands from south africa
Question edited for clarity. Question moved to Casio Point of Sale. Currency Programming. One article says Pounds and Euro, and the other says Euro and Local. https://www.google.com/search?q=casio+se-g1+program+currency ..
3/23/2022 12:21:59 AM • Casio Parts Cash... • Answered on Mar 23, 2022
I need keys for a Casio PCR-265P cash register and manual
Hi.
You will need to get them from a dealer. Look up your nearest one in the phone book.
Mark
2/26/2022 6:54:47 PM • Casio Parts Cash... • Answered on Feb 26, 2022
2answers
I bought a used Casio PCR-265P cash register. It
Hi.
Register keys are different from most other keys, so you can't get them made. You need to find a dealer in your area.
Mark
2/26/2022 6:49:54 PM • Casio Parts Cash... • Answered on Feb 26, 2022
2answers
My Sharp Cash Register (ER-A410) won't turn on in manager mode
Hi.
It is usually caused by a faulty or dirty mode switch. The first thing to try is squirting a bit of electrical lube down the key hole (WD40 or similar works fine), then turn the key back and forth a few times. Otherwise, the contacts inside the switch may have failed. I have also had a loose connector on the main board cause this in another model, so you could try pushing the connectors inside and make sure they are tight.
Hope this helps. You can set the void button to work in REG mode if you don't want to get the MGR mode fixed. Just let me know and I can look up the codes for you. You should be able to refund items as well (unless this has been set work in MGR mode also).
Mark
2/8/2022 3:34:35 PM • Casio Parts Cash... • Answered on Feb 08, 2022
My casie ce-3700 is showing error code 08, how can
You have logged yourself off. Try pressing 1 then CLK#
If anyone needs a Casio CE-3700 manual, C-tech has them here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
1/29/2022 6:07:15 AM • Casio Parts Cash... • Answered on Jan 29, 2022
Need operating manual for Geller NT-1081
You can download a manual here for
4.99 Pounds
http://www.eposwizard.co.uk/catalog/geller-nt1081-programming-operation-manual-p-423.html?osCsid=03b8d93971525f0e1b634a1cdca79f38
I do not have any affiliation with this website. hope the information is usefull to you.
10/27/2021 5:53:54 PM • Casio Parts Cash... • Answered on Oct 27, 2021
Error code E009 on Casio PCR-T500 cash register (enter password)
I believe it is password required.
10/24/2021 9:19:02 PM • Casio Parts Cash... • Answered on Oct 24, 2021
2answers
Pcr t290 PAPER WON'T ADVANCE
Make sure the paper is the correct width. Does it print or advance if you try to print a daily report?
8/30/2021 4:57:43 PM • Casio Parts Cash... • Answered on Aug 30, 2021
2answers
How to change the price on a casio te-4500f till
Model number?
6/6/2021 2:19:22 AM • Casio Parts Cash... • Answered on Jun 06, 2021
2answers
Sharp xe-a20s locked up
Hi.
Yes you are right. you have logged yourself out of the machine. it is telling you to log back in.
Press 1 then CLK# or CASH#
Mark
5/27/2021 11:56:11 PM • Casio Parts Cash... • Answered on May 27, 2021
I can’t figure out how to program the store name and address on the previous store and address
I am pretty good at guessing 'Mystery' items, so I have changed your category. That is where my Clairvoyance ends. Google make model manual They are ALL online, especially all the Casio Cash Registers. The Casio site is excellent.
2/15/2021 8:14:51 PM • Casio Parts Cash... • Answered on Feb 15, 2021
2answers
Just purchased a casio PCR T2100 cash register,
1. Turn key to program
2. press 2 subtotal
3. press 132 subtotal
4. enter commercial message using alphabet keys on keyboard (21 character max per line, 4 lines)
5. press cash at end of each line.
6. press subtotal when done
7. turn key back to reg
10/27/2020 11:17:57 PM • Casio Parts Cash... • Answered on Oct 27, 2020
2answers
Error code Eo2
HI.
Error 2 means no clerk code entered. You need to log on to the machine with your clerk (PIN) number, then press the CLERK or CLK# button. Then it will let you make sales.
If you have trouble, just let me know.
Mark
10/24/2020 6:45:04 AM • Casio Parts Cash... • Answered on Oct 24, 2020
I want to connect my casio CE-4000 cash register with my computer
Sorry. Far too old. No connectivity whatsoever for this model. It was a very low end register.
Mark
7/14/2020 6:31:14 AM • Casio Parts Cash... • Answered on Jul 14, 2020
Casio Parts Cash Register PC Desktop Logo
3,175 questions posted
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Retail Supplies
Most Popular Question
reset grand sales casio te 2000
  • Retail Supplies
