20 Most Recent Jazz DV-179 Digital Camera Questions & Answers
3answers
Jazz DV179 Instruction Manual???
I had that camera and have some backed up files/manual I can send you. [email protected]
2/25/2021 10:35:59 PM • Jazz DV-179... • Answered on Feb 25, 2021
2answers
Movies taken with camera can't be viewed once on pc
It sounds like you need to download the codec to be able to play back the video. It'll be xVid or something like that. I'm not entirely sure what you need, but it definitely sounds like a missing codec.
12/2/2019 9:14:40 AM • Jazz DV-179... • Answered on Dec 02, 2019
3answers
File won't play video
The reason that the video is not playing is because the video uses certain "codecs" to decode the video. (It is basically a way that the computer interprets how to display the video on your screen.)
You need to install a good codec pack so that you can play all formats of video and/or audio.
I recommend using K-Lite Mega Codec Pack. It plays everything from Windows Media (AVI) to Quicktime files and just about everything in between. This is a very widely-used and popular codec pack. It also comes with a much simpler version of Windows Media Player. (It shows as an older version...and even looks like an older version, but it is only based on the older version as it honestly worked much better than newer versions.)
Here is the link.
(Click HERE to download the codec pack.)
Just use the DEFAULT installation. Don't change anything. There is no need to. Once it is installed, it will use the version of Windows Media Player that I just mentioned by default.
But if you still wish to use version of Windows Media Player that you currently have installed, then you may feel free to do so. It will still play videos using the same codecs that were installed by K-Lite. (All A/V programs will use the codecs.)
Another player I have recently found is GomPlayer. Very nice interface. Clean and easy to use. Install K-Lite and try out GomPlayer if you like afterwards.
HERE is a link. According to the site, you may not have to install any other codec packs after installing GOMPlayer. That may or may not be true. It IS OK if you install both.
Good luck. Let me know how it goes. :)
Cyryl
7/17/2019 6:42:48 AM • Jazz DV-179... • Answered on Jul 17, 2019
2answers
Trying to figure out once I have my videos on my
You will need t have a DVD burner software like Nero Burning ROM, ROXIO DVD creator etc., You should then install the same and select the Movie DVD option, drag and drop files into the burn list and burn them to a DVD. If you want more help please let me know once you have obtained a DVD burner software and I will guide you further.
Sai.
7/9/2019 6:04:21 AM • Jazz DV-179... • Answered on Jul 09, 2019
Issues with my jazz dv179 digital camea
As 'it' says, the drivers are not compatible with your OS.
8/1/2017 12:33:21 PM • Jazz DV-179... • Answered on Aug 01, 2017
Jazzy 1113 new batteries not holding charge
On paper those batteries are both the same. There are some subtle differences. Without using an amp meter on your chair, it is not possible to say if things have changed on the chair that cause it to pull more current out of the battery. Motor wear, gear and bearing/axel lubrication can affect the amperage that the chair needs to have. This can adversely affect the battery discharge rate.
3/25/2017 1:44:29 PM • Jazz DV-179... • Answered on Mar 25, 2017
2answers
I found my jazz179 camera after 4 years dosent starte do you know
Flat battery / corroded battery ?
3/22/2016 8:00:45 PM • Jazz DV-179... • Answered on Mar 22, 2016
Digital Canon SLR Cameras
This should work as long as you have the correct converter ring for the camera.
1/8/2015 11:24:34 AM • Jazz DV-179... • Answered on Jan 08, 2015
How to download pictures from camera to laptop
before you can download pictures, you should install the software that came with the camera. On the CD are not only drivers for all known operating systems, but also the software, needed for the computer ro recognise the camera and to stream the pictures to the computer. If you don'e have a CD anymore, try the website from the firm where the camera came from. Or use software like lightroom, gimp or Flickr
5/22/2014 7:35:24 PM • Jazz DV-179... • Answered on May 22, 2014
0answers
0answers
WONT POWER ON
Be the first to answer 1/13/2014 4:08:39 PM • Jazz DV-179... • Posted on Jan 13, 2014Be the first to answer
Jazz DV-179 Digital Camera Logo
399 questions posted
Top Jazz Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jazz Camera Expert? Answer questions, earn points and help others
View Most Popular
Jazz Cameras
  • Jazz Cameras
Most Popular Question
want restore deleted videos off jazzdv
  • Cameras
