20 Most Recent LG 37LC7D 37 in. LCD HDTV Questions & Answers
4answers
LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
6/19/2019 1:57:27 AM • LG 37LC7D 37 in.... • Answered on Jun 19, 2019
3answers
Medion lcd hd 31.5 inch tv won't turn on
I bought one also from ALDI for my son's Xbox 360, it is only 3 weeks in use and I have the same problem. The red led is on, indicating that it is in standby mode and recieving power but I can't turn it on either by pressing the power on button on the TV it's self or the on button on the remote. This started happening a few days ago and it's totally random. I found that if you unplug the TV from the power point or alternatively switch off the power point for a minute, than power it on again it will "WORK AGAIN" for a while. Like I said it is random, eventually it will return to the not being able to be switched on state at which time you will have to repeat the process. So thus, this is not really a solution. I am about to return the TV for a refund, and it's a shame because otherwise it's not too bad. and looks OK too.
7/20/2018 3:49:49 PM • LG 37LC7D 37 in.... • Answered on Jul 20, 2018
Tv sensor doesn't work
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. https://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
3/3/2018 2:17:37 PM • LG 37LC7D 37 in.... • Answered on Mar 03, 2018
0answers
HEY DAWNN,I HAVE THE MOD.# AND SERIAL# FOR MY LG 37LC7D FLAT TV POSTED,THANKS.
Just change the board unless its just a fuse that is blown
11/15/2017 12:25:47 AM • LG 37LC7D 37 in.... • Answered on Nov 15, 2017
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
7/17/2017 1:19:00 AM • LG 37LC7D 37 in.... • Answered on Jul 17, 2017
Audio out of sync with video on LG 37 LCD
Do a factory reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
4/7/2017 4:10:04 PM • LG 37LC7D 37 in.... • Answered on Apr 07, 2017
LCD TV - INTERMITANT BLUE SCREEN
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair. If you wish to get some more details then check the following link. http://electro-medical.blogspot.com/
7/13/2016 5:25:07 PM • LG 37LC7D 37 in.... • Answered on Jul 13, 2016
Lg 37lc55-za power problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ If blinks continue without any pause, the main board is faulty.
6/10/2016 4:23:21 AM • LG 37LC7D 37 in.... • Answered on Jun 10, 2016
Loud cracking and zapping coming from tv,sounded like speakers,when it was first turned on.Was happening intermittently but now nothing.Checked power and fuse inside and nothing seems burnt or cracked
Something has blown.. possibly a resistor, diode or ??? on one or more of the boards. You should take the TV to a service Agent who should be able to resolve the problem.
4/11/2016 1:47:52 AM • LG 37LC7D 37 in.... • Answered on Apr 11, 2016
37 inches lg problem green light on but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/3/2016 6:26:03 AM • LG 37LC7D 37 in.... • Answered on Apr 03, 2016
For months tv had loud cracking noise when first switched on but worked, now just blank powered up screen. Nothing obviously burnt inside.
Did you check with the instructions that came with you when you bought it?
4/3/2016 4:48:28 AM • LG 37LC7D 37 in.... • Answered on Apr 03, 2016
LG 37LC7D HDTV just went
My lg 37lc7d is having the same problem. My backlight is on but no display. Also the standby light blinks several times then the screen goes on but it's just all black. No a/v
2/24/2016 2:22:49 PM • LG 37LC7D 37 in.... • Answered on Feb 24, 2016
TV won't work after disconnecting toggle from tv
Just try a hard reset to this TV, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
10/26/2015 9:50:22 AM • LG 37LC7D 37 in.... • Answered on Oct 26, 2015
Why my lg 37 inch want come on
The inverter board is responsible for the backlight.
10/7/2015 1:00:34 AM • LG 37LC7D 37 in.... • Answered on Oct 07, 2015
2answers
I have a LG 37LC46 lcd tv. Power is going through the set but no picture. Just error message "not programmed" and then blank screen. Happened very suddenly please can you help?
When the screen goes blank, dim the lights in the room. Take a bright flashlight and shine it on the panel. If you see a faint picture, you have a backlight failure
2/4/2015 11:51:13 PM • LG 37LC7D 37 in.... • Answered on Feb 04, 2015
LG 37LC7D 37 in. LCD HDTV Logo
324 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
months tv loud cracking noise when first
  • Televison & Video
