20 Most Recent Samsung LNT5265F 52 in. LCD HDTV Questions & Answers
2answers
On my sumsung lnt5265f 52 in hdtv lcd tv the power
The issue has been resolved. I removed the back of the TV (pretty easy actually) by laying a blanket over the kitchen table and placing the TV face down. I started with the power supply as an obvious beginning. Both fuses on the board tested fine. And touched up every solder joint with a hot soldering iron in case the problem was a cold solder joint. After this painstaking venture, I performed another visual inspection and noticed a capacitor that had a thin black X on the top of the can. This is a common sign the capacitor has over heated. I located a replacement for $1.20, installed, and successfully powered up the TV. I have had no problems since.
Oh, yeah, I also paid $120 for a BN44-00150A replacement power supply, plus overnight shipping. It actually arrived three weeks later. That was two weeks and six days after I fixed the power supply myself.
[email protected]
11/11/2019 6:03:34 AM • Samsung LNT5265F... • Answered on Nov 11, 2019
My TV, Samsung LN-T5265F has 4 inverter boards. I
We can't detect a faulty board by smell, like dogs do. You should check its circuit. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5/19/2017 3:45:23 AM • Samsung LNT5265F... • Answered on May 19, 2017
This TV constantly shuts itself off.
4/15/2015 8:31:32 PM • Samsung LNT5265F... • Answered on Apr 15, 2015
CBS blinks on and off on Dish network
Since it only happens on CBS it is most likely a signal issue. definitely contact DISH
1/3/2015 4:24:30 AM • Samsung LNT5265F... • Answered on Jan 03, 2015
Tv clicks with no picture
This is a common problem with all Samsung flat panels. The problem is caused by faulty capacitors on the Power board. It is an easy fix if you have basic soldering skills. You can also call Samsung and see if your tv is covered under the class action and they will send a tech out to replace the board.
10/3/2014 11:34:28 AM • Samsung LNT5265F... • Answered on Oct 03, 2014
How do i confirm i have a bad inverter board?
can be inverter or the ccfl light itselve. if there are multiple ccfl's probably the inverter or powersupply. check for bad capacitors.
9/28/2014 3:45:57 AM • Samsung LNT5265F... • Answered on Sep 28, 2014
RAINBOW EFFECT AFTER ABOUT AN HOUR OF VIEWING
either a bad lvds and tcon or a bad smps
4/17/2014 11:05:13 PM • Samsung LNT5265F... • Answered on Apr 17, 2014
Picture starts fine but begins to rainbow or get discolored after about an hour
Could be a bad tcon and lvds. If not, it would need a new display.
4/17/2014 11:04:12 PM • Samsung LNT5265F... • Answered on Apr 17, 2014
No audio
Either gonna be an issue with your speakers or more likely it will be that you need to replace the main pcb. What is the model and version # for your tv?
4/17/2014 10:46:58 PM • Samsung LNT5265F... • Answered on Apr 17, 2014
0answers
Vertical lines
Most likely the lines are coming from a failing LCD panel tab connection. The capacitor problem and LCD tab problem are the most common problem for older Samsung LCD's
9/14/2013 2:17:50 AM • Samsung LNT5265F... • Answered on Sep 14, 2013
The screen blacks out intermittently when we play 1st person shooter video games on a PS3. How doe we fix this?
try to adjust the TV resolution to fix the issue..It refer in manual..
10/17/2012 4:20:54 PM • Samsung LNT5265F... • Answered on Oct 17, 2012
0answers
Samsung 52 inch LNT5265F has
This sounds similar to a known problem with bad capacitors in some Samsung TVs. Even though the TV is out of warranty, Samsung extend the repair period for affected TVs. Get your TV model and serial number off the back and then call Samsung at: 1-800-Samsung (1-800-726-7864). Explain the problem and let them know that you have heard about similar problems and heard they were being repaired out of warranty. In my case, they sent a tech out and did the repair for free. If for some reason they will not do it, the repair is quite simple for someone who can solder and you can find details here: http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
10/16/2011 11:51:07 PM • Samsung LNT5265F... • Answered on Oct 16, 2011
Tv turns on for a
Most likely your backlight inverter is defective. On a set this big, the inverters should be seperate boards. It could also be leaky caps in the power supply, or a defective mainboard that isn't holding the "BL ON" signal. The tv is repairable but most repair shops will want to gouge you on price.
9/21/2011 6:30:06 AM • Samsung LNT5265F... • Answered on Sep 21, 2011
2answers
When turning on TV Samsung 52 , 3 years old it
This is common problems for LCD tv,most likely because bad components parts call capacitors on the tv power supply board.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or roll of desoldering braid also can do basic soldering and understanding basic electronic?Take the tv aparts.Yes,check all over the power supply board for capacitors parts are bulging up or puffing up.By replacing all these dying capacitors components parts,will help ur tv LED power light stop blinking and the tv will work right away.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
8/8/2011 9:53:36 PM • Samsung LNT5265F... • Answered on Aug 08, 2011
Samsung LNT5265F 52 in. LCD HDTV Logo
92 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
t con board located in samsung
  • Televison & Video
