20 Most Recent
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Questions & Answers
The control panal on freezer door says 56-56 will not despence water or ice
Good Afternoon Friend,
I understand that you are receiving a 56 56 code on the display of your Frigidaire refrigerator, model# GLHS269ZDB. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 56 is actually SB SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
I have a fridgidaire refrige
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again.
http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out! Thanks to Jake!
Alarm going off and can't stop it
Have you ever heard an alarm go off? Secondly, have you ever heard an alarm COME ON? Which was louder?
What you probably hear is a power failure alarm. Unplug it for a few minutes, then plug it back in and see if it clears itself.
How do I activate the self cleaning method of my
remove racks,shut door select self clean on computer,push up or down arrows for clean time amount and it should lock door and begin cleaning....always select the minimum amt of clean time allowable,for this will minimize chances of damage to your oven,if not clean after use-wait 24 hrs before running self clean mode again
Why does my freezer keep freezing up then leak all over the floor
Hallo
1:Check your door seals(damage door seals causes fridge to suck humidity into the fridge causing it to ice up to much and then the pan type humidifier at the back of the bottom of the fridge can evaporate the water fast enough causing an over flow).
2:If door seals aren't damage I would say at this moment its cold where you live and it would also cause high humidity and there for your thermostat should be set to min:2 and max:3 your choice and try to prevent opening the door to much or keeping it open for 2 long.
3:Ievel the fridge ensure that its level.
4:If the problem still occur let me know.
Regards
Compressor failed and was replaced by technician.
It(evaporator) may have been the reason for the original failure. If he did a poor job brazing the new compressor it could have caused the restriction. If he failed to replace the filter drier it could have clogged. If he did not vacuum the system from the high and low sides it could have caused a restriction.
He could open the system,replace the filter drier,blow nitrogen through the high and low sides to clear a restriction possibly without having to replace the evaporator. Then pull a thorough vacuum and recharge refrigerant with a weight scale.
