20 Most Recent Mitsubishi WD-Y577 Television Questions & Answers
Wd-y577 error code 3 4
check out steps-by-step guide to fix error code 3-4 at: https://mslivesupportchat.blogspot.com/2019/01/error-code-3-4.html
2/12/2019 7:10:50 PM • Mitsubishi... • Answered on Feb 12, 2019
Cannot get the two thumb screws to thread in.
get another housing if possible........take the lamp out, it's held in by 2 screws and metal brackets....good success, meder's tv service
10/15/2013 11:29:19 AM • Mitsubishi... • Answered on Oct 15, 2013
White dots on screen
Your DLP chip is failing. The tiny micro mirrors within this chip are stuck. More white dots will appear over time until it looks like a star field on your screen. Most places will tell you that you need a new light engine, however you can replace the DLP chip itself and it will take you about 30 mins. You can find the chip online for around $349 but I think I have DLP chip you need brand new for $225. If you are interested in this contact me. [email protected]
3/19/2011 4:36:52 AM • Mitsubishi... • Answered on Mar 19, 2011
White pixel are appearing on
Hi, Your problem has to be a defect in the optical engine. Cost of replacing this unit can run from $800 to $1200. Call Mits at 800-332-2119 with model, serial and date of purchase. They should be willing to help. Thx
Bill W.
integrityhomeworx.com
3/7/2011 10:53:11 PM • Mitsubishi... • Answered on Mar 07, 2011
Replaced the lamp in my mitsubishi 57731
THE PROBLEM CAN BE CORRECTED BY REPLACING LAMP WITH THE ORIGINAL LAMP FROM MITSUBISHI CHECK THE ORIGINAL LAMP HAS A MAGNAFIER ON TOP OF THE LAMP.
12/19/2010 7:11:25 PM • Mitsubishi... • Answered on Dec 19, 2010
No sound or video on Mitsubishi WD-Y577.
U check the tv Ballast board?This board it is to help the projection lamp to ignite.
12/6/2010 8:02:57 AM • Mitsubishi... • Answered on Dec 06, 2010
I changed the bulb on my wd-y577 it turns on for a
CK the Lamp Fan if it stops running when Lamp starts to light set will shut off.
Ballast board is what powers Lamp on.
10/28/2010 9:25:12 AM • Mitsubishi... • Answered on Oct 28, 2010
Screen is dim. Have brightness turned up to max
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
3/15/2010 2:32:43 AM • Mitsubishi... • Answered on Mar 15, 2010
2answers
My tv blinks 6x red and 1x yellow. whats that mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
1/9/2023 7:23:43 AM • Mitsubishi WD... • Answered on Jan 09, 2023
0answers
How to replace the main board on a mitsubishi WD-60C8
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
1/18/2018 11:51:33 PM • Mitsubishi WD... • Answered on Jan 18, 2018
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
1/2/2018 10:55:36 AM • Mitsubishi WD... • Answered on Jan 02, 2018
Mitsubishi WD-Y577 Television Logo
Popular Tags
16 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
white dots screen
  • Televison & Video
