20 Most Recent Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Questions & Answers
2answers
I have a samsung RS2530
How do you adjust the temperature
9/21/2018 1:11:01 AM • Samsung 24.8 Cu.... • Answered on Sep 21, 2018
0answers
2answers
Need to replace water line inside freezer door.
Water lines inside doors are typically not serviceable as the insulation is "foam in place". Pulling apart the door and reassembling will be next to impossible. Generally the door would need to be replaced.
3/29/2016 3:10:47 PM • Samsung 24.8 Cu.... • Answered on Mar 29, 2016
The screen on my ice maker/water says 0F on both the refrigerator and freezer.
The first question I have is the length of spent unplugged. I would keep it unplugged for at least 15 minutes to allow all the capacitors to discharge. I'll keep thinking, just let me know if the above works.
10/30/2014 2:51:52 AM • Samsung 24.8 Cu.... • Answered on Oct 30, 2014
Samsung refrigerator rs267tdbp nat cold freezer working fine
I had the very same issue. The freezer is actually responsible for cooling the fridge via fans. On the back of the fridge there's an access panel near the top containing 2 boards. The large one is the control bd. Make note of the connections and remove the board. Right where these fans plug in there are 3 switching transistors and a power regulator. Replace all 4. This is a common issue. A good place to get these is at digikey.com. even with shipping they only cost less than $10 USD. Also, on replacement, put a THIN coating of heat sink compound. You can get it at the same place or Radio Shack.
9/11/2014 7:56:41 PM • Samsung 24.8 Cu.... • Answered on Sep 11, 2014
0answers
How do I defrost my samsung freezer without
A hair dryer or very carefully using a heat gun.
6/5/2014 4:11:43 AM • Samsung 24.8 Cu.... • Answered on Jun 05, 2014
0answers
Removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
8/16/2013 9:44:51 AM • Samsung 24.8 Cu.... • Answered on Aug 16, 2013
Where can i download a service manual for a samsung refrigerator rs26zush
the refrigerator is not cooling
3/28/2013 9:33:45 PM • Samsung 24.8 Cu.... • Answered on Mar 28, 2013
Freezer not defrosting
Unplug it and let it thaw out.
2/5/2013 4:19:37 PM • Samsung 24.8 Cu.... • Answered on Feb 05, 2013
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
97 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung rs2530
  • Refrigerators
