20 Most Recent
LG 42LB5D 42 in. LCD Television Questions & Answers
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Menu codes
LG-42LB5D-UC Service Manual and Repair Guide
LG 42LB5D UC Service Manual and Repair Guide Download Manuals Technical
Official factory service, repair and workshop manual. This service and repair manual is used by the Certified LG Technicians. It will help you to troubleshoot and repair your television!
Please note this is the OFFICIAL service manual in PDF format, no scanned in or bootlegged copy. This manual is made in the highest resolution, so when you print the pages you need it is all in great quality.
Tv over heats then turns off
This would be a shop repair in most cases----yes, some people (my self included) have resorted to a small high speed fan to locate the area that is getting too hot etc---if you find it the fan will prolong the operational time--the real reason is to find which board is bad which is how these sets get fixed---replace a board-----keep in mind that it is possible to change each and every board and to still have the problem------screen unit can be bad and that is fatal.
No sound with colored line on screen
If you have tried using different input devices, looked for loose contactsin power outlet, RC Jack, cable and connectors, the TV might need service.
Remote does not work
most of the time what is wrong with a remote is not that it is broken but theat is is dirty . clean it gently with alchol on q tips and clean the little light and on the receptor that light also so that they can communicatehopeit helps ps dont leave any fuzz and use blow dryer to completely dry before reinserting the batteries (wipe their contacts good also ) hope it help :)
No picture no sound when tv is on 42lb9df-ad
That problem is usually have 2 causes..Its either power supply board or main board..Please take this steps on how to determine the problem:1. Open the back cover.2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..4. If the power supply output is normal..The problem could be on the main board...5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..Hope this solution will be helpful..Thanks for using fixya...
