20 Most Recent
Sony Ericsson W850i Cellular Phone Questions & Answers
Will not download games
you can download the games and copy then into your games folder when you do the file transfer when the phone is connected to the pc.
Phone will not allow me beyond startup
Friend, W-850 is CID based phone. You have updated it and it got it's original flash which was generated for it. Now u have to unlock it again. You see, this all are happened due to special security of CID chipset. You should not update it but when u do that now unlock it. Go to technician who got SETOOL, CRUISER BOX or any other comapitable unlocking tool. He will charge you little. Find the servicemen arround you on FIXIYA and thanks FIXIYA for solution ( Only if u find it helpful)
I forgottem my phone lock code,how can i inter in to my mobile?
Was the phone locked? Or the SIM card?
Because if the SIM card was locked then type in 3 times a wrong pin, then they'll ask you for a PUK code, call your service provider and ask them for your PUK code.
If the phone was locked- in other words, you put a pin to prevent people from using your phone by changing SIM cards- then I'm sorry I can't help you.
Iam useing sony ericsson w850i for past 1
from my own experience and idea, I think that flashing light indicates low battery.
This is usually common with Sony ericsson phone, it flashes a red light once battery is low and you want to power is on.
Maybe should test your phone with another battery.
All the best.
W850i slow and damaged...
sorry to tell you but water damage in a phone is like cancer
your phone will eventually die from it
How to download free mobile mtv videos in you tube
Make sure you have a you tube downloader, then download it to your pc, then download it using a data cable or bluetooth device, make sure you convert the video first in a supported format of your celphone, after downloading it from you tube.
Cant hear nothing!!!
Yes the problem is coming from the speakers , so take the phone to a repair center and have them replace the speakers for you.
Camera won't start "Another Application is running"
Dear Friends,
I have the same problem (Application is still running close it and start the camera) from last Week onwards, i went to the sony ericson service station, they told some Part(board) to be replaced and It will take 15days hardly,I dint accepted his comments, Then i worked full fledged on this and i got the solutions,
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Any queries,
Call me on my hand phone:
My Number: 9940097172
Rgds.,
Nagoor
