20 Most Recent
Nokia 2310 Cellular Phone Questions & Answers
Master reset code
Try this
- First Switch On your mobile by pressing power button.
- Then, tap this code: *#7370#
- Now your phone will restarts.
- Wait for a while, Hard Reset done on your mobile.
Forgot the security code
hi if the phone is asking for the security code as soon as you switch it on then i can give you the master code that resets the code to what it was when new usually 12345 the code only works if its asking for security code when you switch phone on.
Also the code is only accepted if the code hasnt been entered wrong more than 5 times if it has been entered wrong more than 5 times then the code wont work the code is in my next post ok let me know if you need further assistance ok
How to Reset Nokia 2310
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Just 5 steps!
1.Goto: http://nfader.z-host.ru/
2.Insert your IM (insert *#06# and get your IM from cell phone)
3.Check "I'm legal owner of the phone with that IME!"
4.Click on "Generate" button
5.Get the security master code for your phone and unlock it
Good luck.
Unlock nokia mobile
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Nokia x1 00
You can try this calculator:
http://unlock.nokiafree.org/
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Sim card rejected
If your Nokia 2310 phone displays an error message saying
"Sim card Rejected" then your phone is probably network locked.To unlock it,visit the site WickedUnlock.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network sim card.
http://www.wickedunlock.com/nokia-2310/rs16wp9/
to reset the security code u need to put the code what comes it ur mind for 5 times....it will lock the phone if it is wrong..IT WILL ASK FOR PUK CODE.take that code frm service provider and enter it in ur mobile...u can set password again.
