20 Most Recent Frigidaire FRS26R4A Side by Side Refrigerator Questions & Answers
2answers
Frigidaire Gallery FRS26ZGEB - 12 years old
you have a defrost problem or damper problem or evapator fan
1) Check the fan in the freezer is running
2) defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
3) check the damper make sure it is opening and cold air is blowing
How you need to repair what defrost part failed
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
8/17/2021 2:41:54 PM • Frigidaire... • Answered on Aug 17, 2021
2answers
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer boardcheers
6/14/2020 10:45:14 PM • Frigidaire... • Answered on Jun 14, 2020
Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
7/14/2019 11:52:13 PM • Frigidaire... • Answered on Jul 14, 2019
My frigidaire side by side freezer is warm
Clean the frigidaire properly and if you the complete process how to check freezer then only try to open internal part. Or else you can contact any professional person who can fix the issue with frigidaire
4/23/2019 9:25:03 AM • Frigidaire... • Answered on Apr 23, 2019
Water Leaking from filter during water usage.
If water is not passing through the filter properly, it will leak.
3/4/2018 6:42:58 AM • Frigidaire... • Answered on Mar 04, 2018
I have a Frigidarie model # GLHS68EGPWO , serial
We have no idea. What did repair man say it needed?
11/17/2017 7:18:41 PM • Frigidaire... • Answered on Nov 17, 2017
2answers
Ice in bottom of freezer
Add a 3/4" x 1" or so clear piece of tubing slid over the existing fill tube. (available at any big box hardware store) I had the same issue until I installed this. You just want it long enough to pass the top lip of the ice tray. Mine was too short and water would run down the inside of the freezer and was a mess. I would also recommend cutting the bottom end at a 40 or so degree angel as it makes getting the ice maker module out a tad easier if you need to remove it. Don't push too hard sliding the clear tubing over the existing tube,. Mine wasn't mounted very well inside the freezer cavity and you could actually push it further in.
11/10/2017 6:54:06 PM • Frigidaire... • Answered on Nov 10, 2017
Side by side frigidaire ice maker not working
Check the water valve at the back of fridge. Are you getting water at the dispenser on the door? If so, the water valve may not be bad, but sometimes water will freeze in the tube that fills the icemaker. Pull it out from the back of the fridge and check it.Hope this helps !
10/11/2017 2:16:00 AM • Frigidaire... • Answered on Oct 11, 2017
0answers
No ice
Sounds like ice maker is bad.
9/13/2017 1:06:47 AM • Frigidaire... • Answered on Sep 13, 2017
0answers
Slow icemaker
Be the first to answer 5/29/2017 5:06:03 PM • Frigidaire... • Posted on May 29, 2017Be the first to answer
I have a Frigidaire FRT15B3AW3, manufactured
Sounds like the heater is overacting.
5/3/2017 4:40:26 AM • Frigidaire... • Answered on May 03, 2017
Plastic Water Line Coiled Inside the Refrigerator
The coiled line is used for chilling the cold water dispenser. Most of the time they are hidden from view, maxresdefault-aa4zdmn3uhwfzlzgruntlaje-5-0.jpg
3/16/2017 10:09:33 AM • Frigidaire... • Answered on Mar 16, 2017
0answers
The ice cubes come with white powder
Hey there....
The white powder in your ice cubes is the water line to the dispencer,The water in the pipe forms a white layer after some time,almost like the kettle around the aliment,you just have to clean the pipe out,i normaly use some hot water with a bit of vinigar,just make sure you flush the system after wards and there you go....
Hope you get it right...
Wouter.
1/25/2017 6:52:17 PM • Frigidaire... • Answered on Jan 25, 2017
Frigidaire FRS26R4A Side by Side Refrigerator Logo
724 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
ice maker making loud noise exrended
  • Refrigerators
