20 Most Recent Jenn-Air JED8430 Electric Cooktop Questions & Answers
4answers
A metal pot lid was set on top of the ceramic cook
In case anyone else encounters this problem here's what
worked for me. I had this happen last night and came here
searching for answers. It did not unloosen on it's own
after being left overnight. Finally this morning I came up
with something that worked for me. Shoot the lid all
around with a hairdryer and use a towel to keep seeing if
it has loosened up enough to move. After a few miuntes of
spraying it with the heat it stared sliding around and then
came up.
11/22/2022 11:05:27 PM • Jenn-Air JED8430... • Answered on Nov 22, 2022
4answers
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
7/20/2021 3:00:05 PM • Jenn-Air JED8430... • Answered on Jul 20, 2021
2answers
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
2/27/2020 7:17:46 PM • Jenn-Air JED8430... • Answered on Feb 27, 2020
2answers
New granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
6/29/2019 10:29:04 AM • Jenn-Air JED8430... • Answered on Jun 29, 2019
2answers
I have a Jenn-Air Electric
hello, this unit does not have a fuse or thermostat to shut it down. it has to be the house breaker or wiring.
2/21/2019 10:03:59 AM • Jenn-Air JED8430... • Answered on Feb 21, 2019
3answers
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
10/20/2018 10:14:07 AM • Jenn-Air JED8430... • Answered on Oct 20, 2018
2answers
Was cooking fudge-hot sugary liquid boiled over
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
9/27/2018 8:41:33 PM • Jenn-Air JED8430... • Answered on Sep 27, 2018
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times. always unplug electricity before attempting to repair on any electrical appliance
10/2/2017 12:50:51 PM • Jenn-Air JED8430... • Answered on Oct 02, 2017
I have a 4 burner Jenn-Air JED8430ADB electric
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair! project4-nbbnxwvnfadegsi2zsme4jri-2-0.jpg project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
5/4/2017 11:36:16 AM • Jenn-Air JED8430... • Answered on May 04, 2017
I have a 4 burner
For free help and parts the best website for this type of home appliance is at the link below. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
5/3/2017 5:28:20 PM • Jenn-Air JED8430... • Answered on May 03, 2017
Right side of hotplates have no power, while left side work fine
I had no instructions, manual, no receipt at all, due to a residential move. I asked questions and described the product numerous times - even went to Office Max to ask for any advice, describing what the Router action was and what was different. They gave me a list of possible Router Companies. This led me back to several phone calls, which did finally help. Guess what - part of the problem was with new techniques at my "Online Provider."
3/8/2016 5:45:18 PM • Jenn-Air JED8430... • Answered on Mar 08, 2016
Broken glass cook top
You probably need to replace it. They are though fairly expensive. A little under $200 to be exact. http://www.partstore.com/ModelSearch.aspx?MfgName=Maytag&BrandName=JennAir&CloselyRelatedModels=true&ModelNumber=JED8430&x=41&y=30
5/22/2015 4:33:45 AM • Jenn-Air JED8430... • Answered on May 22, 2015
How to take off top of cook top to access the control for one of the burners?
Ok Hello there. Number 1) There are several types of this 8430 but all will be similar . For the complete set of machines if you REALLY need the EXACT one.go here http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JED8430&siteCd=JA_EN_US&userType=Servicer#installation_instructions Number 2) PLEASE don't 'fiddle about' with the cooker if you don't know about electrics. There are VERY high powerand DANGEROUS electric cables in there ! This is Nothing like a low power Stereo or TV BE CAREFUL !!!! Number 3) I am not familiar with this top but it seems from the diagrams that it just drops in to a base unit that contains the fan unit.somehow. I don't see any screws in the surface of the top so TURN OFF THE POWER COMPLETELY take out by lifting the edges ; the whole thing and work on it from underneath to access the electrics.. These diagrams below will show you all you need to do the job. READ THEM THOROUGHLY BEFORE you start. PLEASE BE CAREFUL with Electrical wiring. !!! I cant stress enough Owners Guide http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208111P415-60.pdf Parts list and circuit diagram (if your switch is playing up.this will help) http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JED8430ADB.pdf Installation http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P419-60.pdf
9/20/2014 7:55:35 PM • Jenn-Air JED8430... • Answered on Sep 20, 2014
The cook top display control lock ? i need to unlock the controls
To Unlock Cooktop: Touch and hold CONTROL LOCK for
5 seconds.
7/14/2014 5:32:50 PM • Jenn-Air JED8430... • Answered on Jul 14, 2014
2answers
I cannot REPLACEMENT KNOBS fOR model # 5D02
http://www.repairclinic.com/Appliance-Parts?s=t-jed8430-%3d%3dc251
This company has your knobs.
5/29/2014 1:32:44 AM • Jenn-Air JED8430... • Answered on May 29, 2014
Jenn-Air JED8430 Electric Cooktop Logo
356 questions posted
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
metal pot lid set top ceramic cook
  • Cooktops
