20 Most Recent
LG RH177 DVD Recorder/HDD Recorder Questions & Answers
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
My DVD recorder LG RH1858 isn't recording
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
I can't play MPEG-4
Refer to its user manuals' specification sheet. You can see all details about the formats that this player can read.
LG RH387 stays on hello message
Hi All I have just had this problem. Note that the DVD reader/writer has packed up and the system will not boot any futher. Replace the DVD/reader/writer and your problem will be resolved
I have a LG DVD
unplug the hard drive inside and see if it boots. if it does then the hard drive needs fixing or replacing.
My RHT497H unit only responds
Get in touch with where you bought it from. They should be able to sort it out. It sounds to me that it could be faulty.
Failed power supply section,what is the problem?
it unfortunately could be literally one of 25 things, the Power Supply is a symptom of the actual CAUSE. You must get a service manual to perform the troubleshooting and fault isolation procedure, and even than it is still extremely hard to isolate, usually one just replaces the Mother Board, and or power supply.But it also may be the laser head, too.
