20 Most Recent
Hampton Bay 73554 Antigua Ceiling Fan Questions & Answers
Fan is wobbly
If you do not have the balance kit that came with the fan, then tape a penny or nickel to the top of the blade (out of sight) that lifts the highest. Try taping the penny close into the motor first to see how it works and if more is needed, then move the coin toward the edge of the blades.
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
I have had a hampton bay antigua plus 56
Try not to take that person serious. I would tighten the screws on the brackets around the fan. Only a phillips screw driver needed for this task. The blades on mine are hardened wood.lol.
However, the problem I have is with finding a replacement bracket:
ST306-002-22
I found that Hampton Bay is a wholly owned subsidiary of Home Depot (look it up). That being said, I contacted Home Depot and the associate had no protocol in getting me in a better direction.
The problem I have is the lacking of integrity shown by Home Depot in this particular situation. I knew nothing about Hampton Bay ceiling fans being that of a subsidiary onto Home Depot. I am a potential customer to the Depot but, will attempt to research all methods possible to save myself an unnecessary trip to flirt with possibility of a non-fitting universal bracket. BALLS!!!
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Capacitor
The best place to find that is back at Home Depot...you may be able to match it up at a local electrical supply house, but usually they are a forgien made cap and are not readily accessible to the consumer in the states...
heatman101
Two days ago my hampton
hi.
DO NOT USE THIS FAN. disconnect if possible.
any spark, smoke and popping noises from any electrical items MUST be treated as highly suspect and a possible fire risk, until professionally tested and given the all clear.
it may just be a few bits of dust burning off, but it MUST be checked before you can assume it is safe.
sparks and smoke with a little dust or grease can cause a fire.
i AM trying to frighten you into doing something rapidly, as this could be a serious fire risk, and must be considered dangerous until tested and proven to be safe.
i would not be doing my job responsibly if i did not make this point absolutely clear
Remove ceiling cover plate of Hampton Bay Antigua.
first
you will need a ladder and a screwdriver/phillips a couple wire nuts or
electrical tape.at the "top" of the fan you will see a bowl shaped
cover it will have usually no more than two screws in it..loosen or
remove those screws to access the fan hanger inside.once you get that
far inside you will see several wires .undo each wire seperatly and
cover with a wire nut or electrical tape(please make sure your power is
off to that circuit) once you have unhooked all the wires from the fan
and secured them out of the way. lift the fan out of the hanger itself
(sometimes it is easier to remove each blade from the motor housing
before removing the fan from its hanger ) those screws can be found at
the base of each blade on the motor housing..If you are moving or adding
a cieling light be sure to remove both parts of the fan hanger..the
second part will still be attached to the cieling..usually two screws
holding it into place..if just replaacing the fan,,you can sometimes
leave the second part there and hang the new fan with it..
look carefully there are screws somtimes with a grommet or paint as these were built in factorys all over the world and are very inconsistent if you rrally cant find screws and it will twist it is always left
left is loose right is tight
lefty loosy righty tighty lol
my grandad taught me that one i always remember
Where can i order a new motor for this model
Check this response from 2008 for same model fan.
By resorrowsr on Oct 26, 2008
Fan
stopped Turning - Removed fan to check all the connections. All the
connections were good. When you turn the fan on, you can hear a humming
sound. If you take off the blades you can spin the motor and it will
work, but will not turn on it's own.
I
called Home Depot customer service. I had my receipt, so they gave me
store credit for the full purchase. Since I have two fans, they wanted
to know if I wanted to replace both fans. I told them one was still
working fine, so I only replaced one. My problem was the transformer.
You could see where it had overheated and melted.
http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=Hampton+Bay+73554+Antigua+Ceiling+Fan&langId=-1&storeId=10051&catalogId=10053
The wires for hooking this fan up are white,black
White (Neutral) White to White
Blue (Light to Hot) Blue to Black (optional)
Black (Fan to Hot) Black to Black
Green (Ground to Ground) Green to Green
If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
