20 Most Recent
HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Questions & Answers
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
3/8/2016 5:16:09 AM •
HP Compaq...
Answered
on Mar 08, 2016
Beeps when is turning on
You need to be more specific... How many beeps? Did you add any new
hardware? Were you doing anything inside the case? Does it boot up at
all? Are there any messages on the screen?
6/26/2012 3:40:51 AM •
HP Compaq...
Answered
on Jun 26, 2012
Bepps when turning on
You need to be more specific. How many beeps? Did you add any new hardware? Were you doing anything inside the case? Does it boot up at all? Are there any messages on the screen?
6/26/2012 3:40:41 AM •
HP Compaq...
Answered
on Jun 26, 2012
What causes a blue screen?
ram issue if safe mode. otherwise turn apps on one by one to see which one is causing it. u can also try load the drivers one by one in safe mode to see maybe a driver is crashed or conflicting with some system code.
3/2/2012 2:21:20 PM •
HP Compaq...
Answered
on Mar 02, 2012
HDD not detected
try to remove the hard drive and try it unto another pc... probably cable problem. if not, maybe faulty hard drive . :(
7/8/2011 4:55:32 PM •
HP Compaq...
Answered
on Jul 08, 2011
Recientemente conecte la Pc a
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro. I’m happy to help further over the phone at
https://www.6ya.com/expert/al_e83b1941f9c0f302
4/4/2011 9:25:47 PM •
HP Compaq...
Answered
on Apr 04, 2011
No video response and beep code, one short and one
On HP, one short and then one long beep usually means a problem with memory. Open up the case and try reseating the memory. If you have more than one, you can try removing them one at a time, trying to boot up each time and see if you can isolate which one is bad.
12/14/2010 3:48:00 AM •
HP Compaq...
Answered
on Dec 14, 2010
No video response power to
Please disconnect all the peripherals, then remove the RAM. Leave the computer idle for five minutes and reinsert the RAM. clean the RAM slots with air blow. Then reconnect the peripherals and restart the computer
12/14/2010 12:07:15 AM •
HP Compaq...
Answered
on Dec 14, 2010
Registry corrupted, no recovery cd available. what
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
11/13/2010 12:07:51 AM •
HP Compaq...
Answered
on Nov 13, 2010
Ok my computer wont boot
Three causes
Bios is not set to boot from CD first
CD is not properly burnt as bootable (often the case in pirate copies of software)
CD rom drive is dying.
8/4/2010 4:10:30 AM •
HP Compaq...
Answered
on Aug 04, 2010
My computer stays on
If the Pc is booting directly to safe mode and the OS windows XP than Simply uninstall the SP3
7/10/2010 7:11:20 PM •
HP Compaq...
Answered
on Jul 10, 2010
I want to add a video card upgrade to my Compaq
NO you would need a extra power supply or upgrade your power unit to at least a 500 WATT see Hp
jips its
customers and puts a 350 watt or a 400 watt in there systems so then you are not going to have the connectors to power that card in the
pci E slot. So you will need to
unfortunately upgrade the power supply. its for your
benefit to do so anyhow.
Any questions let me know, please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/27/2010 3:36:40 AM •
HP Compaq...
Answered
on Apr 27, 2010
