20 Most Recent
Konica Minolta magicolor 5550 Laser Printer Questions & Answers
I installed new, genuine Minolta
The common causes of this problem are:
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
If it's 3, sometimes you can clean them by cleaning the contacts on the old"empty" cartridges, then installing/removing them a few times.
This probablyhappening because there may be excess ink on caked on to the contacts on thecarriage. They're pretty easy to clean and the cleaning process takes about aminute. Just remove whatever cartridges are in the printer, take a cloth thatwill leave a minimal amount of lint, and wipe at the dark spongy contactslocated just below where the cartridges would sit. When the caked on ink isremoved and all you are wiping at is the sponge, insert the new cartridge andthe printer should work.
Now you needto Resets the printer settings to their defaults. For that you can simply pressreset/clear button or go to SYS DEFAULT MENU - RESTORE DEFAULTS - RESTOREPRINTER.
Hope this will help you. Good Luck.
Konica minolta magicolor 5440dl
I'm assuming these are Black lines?
1-check the fuser, the part where it exits and gets HOT,
the rollers must be shiny and clean, if the coating is starting to wear off it retains some toner on it causing lines or copy quality issues.
