20 Most Recent Konica Minolta bizhub C450P Laser Printer Questions & Answers
2answers
Background bizhub c450
Background Explain!!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/21/2021 6:31:30 PM • Konica Minolta... • Answered on Dec 21, 2021
2answers
Bizhub C450 error code c-b116
Fax board error did you replace it or remove it?? was it installed ? did you install correctly there is a procedure
8/10/2020 2:16:29 PM • Konica Minolta... • Answered on Aug 10, 2020
3answers
Error code c2152
good toImax Konica Minolta C451 BizhubI have a problem is the cod C2151 what to do Thanks
4/12/2020 9:19:59 AM • Konica Minolta... • Answered on Apr 12, 2020
Error code c2558 for konika bizhub 215
Abnormally high toner density detected black TCR sensor TC ratio in the imaging unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively. check for developer check TCR sensor check toner sensor check the PRCB
3/25/2020 10:28:17 PM • Konica Minolta... • Answered on Mar 25, 2020
Bizhub c451 c3724
power error code
4/20/2019 4:11:57 AM • Konica Minolta... • Answered on Apr 20, 2019
Malfunction detected c 2557 ib Bizhub C450
Abnormally low toner density detected Black TCR Sensor.
4/17/2019 5:02:54 PM • Konica Minolta... • Answered on Apr 17, 2019
Error code ccf01
One of the rarest machines in the Konica Minolta line up!!!!! A printer without a control panel. the code deal with one control board not talking to another, recommend a tech look at it he might be able to re-flash the firmware the copiers operating system worse case one or both boards are bad. Is the machine on a good surge protector not an Ace hardware 9.99 special? Nothing against Ace. But a thousand dollar machine should be protected with a good minimum 100 dollar surge protector. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/2/2019 6:35:19 PM • Konica Minolta... • Answered on Mar 02, 2019
2answers
Hi, on Konica-Minolta Bizhub C450
Am having little Challenge if I send job to printer Bizhub c451. D job will enter printer and it will wrote System Printing and it will not print
10/23/2018 7:15:17 PM • Konica Minolta... • Answered on Oct 23, 2018
3answers
I am getting a yellow background when printing on bizhub c450, no background when photocopying
Problems bizhub c452 print dust
10/11/2018 11:34:06 PM • Konica Minolta... • Answered on Oct 11, 2018
3answers
C-B003 fault on my new bizhub c253
FAX Board Error DO U HAVE FAX ON THIS MACHINE
9/10/2018 4:09:24 PM • Konica Minolta... • Answered on Sep 10, 2018
2answers
Error c4765 in my product Konica minolta c450
Pls to slow help me
5/26/2018 2:26:02 PM • Konica Minolta... • Answered on May 26, 2018
Konica minolta bizhub c450 error codec-d357
DID you swap a board from a different machine if so you really messed up the machine, Have a tech come out to look it over mite run below? NVRAM holds the serial number and counts so people cant erase the counts as new. CD3##: NVRAM Data error • When the data stored due to the NVRAM trouble is lost, backup data can be used for restoration. • Trouble code [C-D370] will be displayed when multiple errors (over 5) of NVRAM data are detected, which can be restored with one restoration command. • Data backup will be automatically performed every hour. Backup can also be performed manually with the following setting. [Service Mode] ? [Enhanced Security] ? [NVRAM Data Back Up] Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ? 1 ? 3 ? 9 2. [*] will be displayed on the trouble code screen. 3. Touch [*]. 4. The screen will be shifted to the data restoration screen to perform data restoration. NOTE • When the restoration is performed in a short time, data restoration screen may not be displayed. 5. Check the message which indicates that the data restoration was successfully conducted. Turn Main power OFF, and wait for ten seconds or more to turn it back ON. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4/7/2018 8:40:04 PM • Konica Minolta... • Answered on Apr 07, 2018
MY KONICA C450 HAS SHOWED ME AN ERROR C-3752
Sir/Mam, Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 8:53:41 PM • Konica Minolta... • Answered on Mar 25, 2018
Solucion para el codigo 38-21 en bizhub c253
replace the fuser and reset the machine Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2018 7:25:07 PM • Konica Minolta... • Answered on Mar 11, 2018
ERROR CODE LIST FOR KONICA C450
C450 P or c450 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 6:00:35 PM • Konica Minolta... • Answered on Mar 10, 2018
I have a bizhub C450 Fiery printer and it was
Well you need to log in as administrator reset the IP address the mask and gateway. it is still on the old net work and was set as static IP address which mean it not set up for DHPC Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 3:12:19 AM • Konica Minolta... • Answered on Feb 25, 2018
4answers
I have a C-2557 code on a bizhub C450
interesting... this information is covered in detail in this post http://www.fixya.com/support/t1232734-bizhub_250_malfunction_code_c2557_help I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
12/18/2017 5:20:09 AM • Konica Minolta... • Answered on Dec 18, 2017
Error scanning documents
try removing the default settings.
11/17/2017 4:45:10 AM • Konica Minolta... • Answered on Nov 17, 2017
C2558
Error code relates to an out of range ATDC sensor level detected on the black I.UIt normally happens when customer does not replace the toner when prompted.It can usually be cleared by opening and closing the front or right side covers thus allowing the machine to cycle and add toner until it reaches an acceptable level.If not cleared after four or five attempts go into service mode and run tcr toner supply for black.(In Image Adjustment)This will clear down the error Or you may need to replace the black IU if that doesnt work.
5/6/2017 9:23:48 PM • Konica Minolta... • Answered on May 06, 2017
C-0212 35c-km error
Behind the machine very bottom where # 3 draw is there is a small hole. Unplug the machine stick a screw driver in there to manually release draw number 3. the Code is dealing with the life section of draw number 3 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 5:29:10 PM • Konica Minolta... • Answered on Mar 12, 2017
Konica Minolta bizhub C450P Laser Printer Logo
325 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
error code c2152
  • Office Equipment & Supplies
