20 Most Recent
Konica Minolta Konica Bizhub Pro 920 Toner 022J Questions & Answers
Bizhub 920
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
The soft switch you want is 03 -1-0
with the code it will be 03-1-1
1. "Service mode menu screen"
Press [07 System Setting].
2. "System Setting menu screen"
Press [01 Software DIPSW Setting].
3. "Software DIPSW Setting screen"
Press the [?], [?] or the numeric keys to select DIPSW bit number.
4. Press [On (1)] or [Off (0)] to set the selected bit number ON/OFF.
5. Press [Return] to return to the "Service mode menu screen" on which the sub menu was displayed. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Sc 35 -02
Fusing unit upper roller thermistoe defective.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON.Keep pressed the Utility key when appear Trouble reset message on screen.Reset and turn OFF the copier.Wait 1 minute and turn ON.
I have a konica minolta c8000 with error code c3106, what does it mean?
Open the mid section of the copier and pull out main section. Then re-install. The code mean the the fuser (The large device on the left hand side that melts or fuses the toner to the paper is not connecting properly to the electrical connections in the back where it plugs into. Could be that the connector is broken because some slammed the mid section to hard. Or that you need to give the section a better/some what harder push when you close it. Might want to remove the FUSER unit and put a flashlight to the back make sure the connector is ok and check the connector on the fuser itself!
