20 Most Recent
Samsung LE37R72B 37 in. HD-Ready LCD Television Questions & Answers
Lcd manuel
download user manual from>>
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/LE37A656-_1
or download from>>
http://www.usersmanualguide.com/samsung/tv__lcd
please rate this solution.
Thanks for using FixYa.
I have a Samsung LED 37
that would be the screen driver failing, the shadow is the memory on the screen control its self the board is on the back of the screen with a lead going to it from the main av board, the board has to be replaced with the same part number, as different ares put different screen in when made you will need the part number from the board and replace it this board with same part number.
Tv
MY TV WILL NOT ACCEPT POST CODE
Connect i pod to tv
You have to be a but more descriptive pal, your not going to get a answer because we need to know what type of iPod. If it's a iPod touch, you need to buy a Apple TV Adaptor.
Well we pluged the cables
Are you using component cables for the video? If so make sure the colours match up between the plugs and the connectors on both the TV and whatever you are using as the video source (DVD player, digital cable or satellite box).
The green plug on the cable must go into the green jack on the TV, blue plug into blue jack etc. It sounds like you might some of them mimatched.
JUST BOUGHT A NEW SAMSUNG
U have a roof or a good antena like a Digital antena?Take that antena wire hook up to the tv hole that said ANT.Now,turn on the tv.Push the button said menu on the tv remote,go to SETUP,go down to CH. push and pick AIR Not CABLE push it again.Now the tv will auto searching for all the DVTV free air stations in ur area.After this ur tv should getting all the free air DTV broadcasting signal in ur area.
