20 Most Recent
Weber Genesis Silver A Grill Questions & Answers
Can I replace burner tubes
Hi Susan
Yes you can replace the burner assy...go to walmart or your local bbq parts house...look at your burner first to get an idea of what it looks like before you go to purchase
Bud
My Weber Genesis Silver only lights on the first
Close the propane tank valve and disconnect the hose/regulator from the tank. Reconnect the propane tank and very slowly open the tank valve. You may have opened the valve too fast causing the built-in excess flow to close to a trickle. If you still have issues, let me know and I'll dig deeper. Douglas
I have a weber E320
It is the gas flowing through the diaphragm of the regulator. It is common here in South Florida where we have alot of humidity. It is nothing to be concerned. You can also spray soapy water around the regulator fittings if you are concerned of any leaking around the regulator.
My Weber Summit Grill is
IS PROPANE TANK RESIGNED TO BE MOUNTED VERTICAL OR HORIZONTAL? The Outflow tube of the vertically mounted tank runs to within an inch of the bottom of the tank. The horizontally mounted Tank Design has an outflow tube that has a 90 degree bend half way down to 1" of the side of the tank if it mounted in the wrong orientation for it's design, it stops picking up LPG halfway down. When used in it's proper application, the orientation would be correct for gas pickup. A tank designed for horizontal mounting used in a verticle position picks up LPG for half of the tank, then it will light (because of the fumes are flammable) but do not posses the density to heat. (Too much Air) in the mixture fuel to air ratio. We found this out after pulling the shut off valve off of a tank with same problem. It was a horzontal tank used in a verticle positiuon. It worked for half a tank of fuel.
Full tank but no gas smell and just bought a new
follow this steps and fix it. God bless youTest the propane tank valve for leaks:
- Turn the grill control knobs on the front (and, on some models, the side) of the barbecue to the off position.
- Turn the propane tank valve fully counterclockwise to close it.
- Mix a test solution of equal parts of dishwashing liquid and water in a small container.
- To test for leaks, apply the test solution liberally to the
connection between the regulator fitting and the tank valve using a
small paint brush. Apply the test solution to the valve handle and
threads, the length of the hose, and the connection between the hose and
the regulator. If bubbles appear at any point, there is a gas leak.
- Tighten the connections and retest.
- If you still see bubbles at any of the tested connections, close the tank valve and replace the leaking component.
Test the hose fittings for leaks:
- With the tank valve open, brush the test solution on the fitting at the other end of the hose, located under the control knobs.
- Turn the control knob to high and test the hose and fittings leading
from the control knob to the grill. Turn the right control knob to off.
Repeat the process for the other control knobs.
- If you see any bubbles during any of these tests, close the tank
valve and contact your propane dealer or your local gas utility. Do not
use the barbecue until the leak is corrected
Battery igniter
If you have an electric igniter, you need to locate where on the side of the grill the battery (e.g. AA size) that generates the electricity for the igniter is located. Replace the battery, and assure the contacts are cleaned (as they may have corrosion if grill located outside). Then check where the ground of the igniter is connected to the grill. I unscrewed the screw where the ground was located, cleaned off the corrosion with a fine sandpaper, then reconnected it to a new screw on the cabinet.
Replace burner tubes
Hi Susan
It is not a hard job so I would say Yes you can replace the burner assy...go to walmart or your local bbq parts house...look at your burner first to get an idea of what it looks like before you go to purchase
Bud
My weber grill sliver a
I would clean the burner , clean igniter with some steel wool and check wire from it is not damaged or fallen off.
My grill is not getting a flame to the back
The cross over burner tube that lights the rear burners may be clogged or has rusted closed. The only way to know, is to carefully remove and inspect it.
I hope this helped you and thanks for choosing FixYa.
