20 Most Recent
Weber Q Grill Questions & Answers
Weber q 220
Sound like the spark electrode needs cleaning on the burners .
Starter clicks but won't light
Let the gas run a few seconds before clicking (and stand back). If that doesn't work, you may need to replace the starter.
Clean burner holes
Just find the biggest nail you can that will fit the hole and ream it out.
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
HaI have a Q100 grill.
No that is not normal and the issue is regulator related. Before you head out to buy parts, try solving the problem this way. Turn the LP Tank Valve OFF. Disconnect the hose from the tank and wait 5 minutes. Them reconnect the hose to the tank and turn the Tank Valve ON Very, Very Slowly (Slow motion, slow). Once the tank valve is fully open, light the burner and turn it to high. Has the flame height returned to normal? Is so, you solved the problem. If it hasn't you will need to replace the grill hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. Be sure to take your old one with you for comparison purposes.
Hope this helped you to solve the problem. Happy Grilling!!
