20 Most Recent HP Officejet Pro L7680 All-In-One InkJet Printer Questions & Answers
Can HP Officejet L7680 All in One Printer print in reverse or Mirror Image?
It is normally a function of the printer driver.
3/19/2015 5:26:33 PM • HP Officejet Pro... • Answered on Mar 19, 2015
My hp7680 says there is a paper jam but there is no paper anywhere. The belt that moves head back and forth seems to be stretched and worn. Is there anyway to replace belt
The paper jam is in the back of the printer. There is a 3"x3"x12" black box. Remover that and the paper is inside. If not call HP support. It is freeand they can fix it with you.
1/21/2015 4:49:03 PM • HP Officejet Pro... • Answered on Jan 21, 2015
My printer only prints magenta\
Hi, A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced This may help You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink. For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode. If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode. If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink. For more Help Source... Can You Fix Dry Ink Cartridge eHow Thanks, HP Phone Number
6/26/2014 10:11:12 PM • HP Officejet Pro... • Answered on Jun 26, 2014
3answers
HP L7680 all-in-one Clear Paper Jam
Hi
Thanks for using FixYa. As you have already tried everything out, what I would say is just unplug the printer hold it in your hand, turn it upside down and just shake it gently. I know this sounds a bit awkward but hopefully this clears a paper jam. If not then please follow these step by step instructions to clear the paper jam:
How to Clear Paper Jam on HP L7680
If after doing all this still the issue is not resolved then unfortunately you have to uninstall its software and reinstall it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
8/25/2013 6:18:48 PM • HP Officejet Pro... • Answered on Aug 25, 2013
0answers
How do I make darker
Go here and see Page 50 also you can goto the troubleshooting area of the manual and look for your problem tfor instruction on how to correct it.
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Please give this a thumbs up if it was helpful, Also if so inclined Feedback is greatly appreciated!!!
Good Luck!!!
6/13/2011 4:02:15 PM • HP Officejet Pro... • Answered on Jun 13, 2011
Keeps coming up with jammed paper - but there is
Check all sensors inside (a small plastic pawls).
Probably there is a small piece of paper stacked near one of them.
5/19/2011 2:24:21 PM • HP Officejet Pro... • Answered on May 19, 2011
I have an Officejet HP Pro L7680 All-in-One
have you clean the head?
12/13/2010 4:01:28 PM • HP Officejet Pro... • Answered on Dec 13, 2010
I have a HP Officejet Pro L7680 and have enjoyed a
Hi
You need to replace the Yellow cartridge
with a new one couse the old one either
has expire or has problem with the chip
on cartridge
ps vote us to keep us alive
11/6/2010 10:21:13 PM • HP Officejet Pro... • Answered on Nov 06, 2010
We have a 7680 HP OfficeJet Pro and the last line
got to control panel, click printers, right click on printer and select properties, go to ports tab and unclick 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
10/2/2010 4:23:59 PM • HP Officejet Pro... • Answered on Oct 02, 2010
2answers
No additional details to add.
if there will be problem with your printer, chat us back..
8/24/2010 8:30:10 PM • HP Officejet Pro... • Answered on Aug 24, 2010
HP Officejet Pro L7680 All-In-One InkJet Printer Logo
38 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
7680 hp officejet pro last line
  • Office Equipment & Supplies
