20 Most Recent
Scotts Miracle Gro Tomato Plant Food 1.5 lbs Case of 6 Questions & Answers
What is the cure for yellow leaf on tomato plants
Usually fungus. You need to plant tomatoes where the sun will dry the overnight dew quickly each day. Don't water at night (water in the morning). Try to water the soil and not the leaves.
Ask your nursery for a fungicide (or if something else is causing yellow leaf in your area). They will know and guide you.
Best set to pull off the dead/yellow leaves to limit cross contamination and spread of the fungus/mold.
How to set when birds chirp on sangtai6168S quartz clock
Setting the Sang Tai 6168 S Bird Clock to chirp during specific hours, like from 6 am to 9 pm (a 15-hour cycle), can vary based on the specific model and its features. However, here's a general guide that might help you set it:
- Locate the Controls: Look for buttons or switches on the clock that control the chirping sound or set the clock's functions.
- Check the Manual: If you have the user manual for the clock, it's the best resource. It typically contains specific instructions on how to adjust the settings, including setting the hours for bird chirping.
- Setting the Chirping Hours: Look for any controls related to setting the active hours for the bird chirping. There might be separate buttons for adjusting the chirping duration.a. Press and hold the button or combination of buttons that correspond to setting the chirping hours.
b. Use the buttons or switches to navigate and select the start time (6 am) and end time (9 pm) for the bird chirping.
- Confirm the Settings: Once you've set the desired hours for the bird chirping, confirm or save the settings according to the clock's instructions.
If you're unable to find specific instructions or controls, referencing the user manual or contacting the manufacturer's customer support might provide clearer guidance on how to set the specific hours for the bird chirping on your Sang Tai 6168 S Bird Clock.
12/22/2023 1:44:36 PM •
Birds
Answered
on Dec 22, 2023
How come I can ask for help on my 63 tbird and you show me everything except a 63?
You can ask for help on and vehicle and any year. You must be talking about the Categories? There are around 10,000 listed by 'maker year model'. Most years are covered but not all. We even have a category for Birds which is where you are because the website script guessed it because of your use of abbreviations. If you put '1963 Ford Thunderbird' as the first three words of the question, you would have been offered the 'Ford Thunderbird' category. There is also the Generic Catch-All category 'Cars and Trucks'. Hope that explains and thanks for using Fixya.
3/24/2023 4:18:44 PM •
Birds
Answered
on Mar 24, 2023
Nectar card replacement
Here is their policy
How do I get a new Nectar card?
Simply fill in our form on the link below and we'll pop a new card or key tag in the post for you. It'll be with you within ten days. If your card's damaged, you can continue using the same Nectar card number. If it's lost or stolen, we'll give you anew card number straightaway.
10/27/2022 5:55:30 PM •
Birds
Answered
on Oct 27, 2022
