20 Most Recent
American Standard Trane Ge Gas Furnace Flame Sensor Sensing Sen00355 Pse-tr9 Questions & Answers
Furnace manual
What is the problem? If its not sensing the flame? Try rubbing off the build up of the carbon on the sensor off with a piece of emery cloth or some sand paper. If it works after you clean it. Replace the flame sensor. It should work for you for a little while after the carbon build up is cleaned off. Not sure of what exactly the problem is. But with a flame sensor the only thing it does is confirm there is a flame to keep the gas flowing thru the gas valve. Its one of the many safety features on most if not all gas furnaces. If you need further help, reach me via phone at
https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
4/2/2014 4:00:34 AM •
American...
Answered
on Apr 02, 2014
Furnace fan will not run manually or otherwise
Check motor winding resistance (line to line and line to body). If this is okay, check if the wires are cut or disconnected to the terminals. If wires and connections are okay, replace the capacitor.
11/13/2012 3:08:30 AM •
American...
Answered
on Nov 13, 2012
I have an American Standard unit showing error 91
Had error code 91 on Trane XL19i thermostat. Heat season on duel fuel system. Repair tech said board is bad ($963) and transducer ($1000). Unit is 3 ton 12 years old. Does it make sense to repair or put in a new unit?
2/21/2020 12:54:27 AM •
American...
Answered
on Feb 21, 2020
I have American Standard error code of 156. What do I do to correct?
american standard error of 156... on a car? If PO0156, thats an ODB2 sensor... possibly the second O2 sensor on your emission system. You can reset the code and see if within 100 miles it lights back up... Likely it will. You may have a burned out catalytic converter... or a bad O2 sensor... or a blown head gasket, or many other things. If that is the ONLY code I would go forward with the O2 sensor. Look it up on ebay, year, make and model of car. Typically if one o2 goes, the other will follow. It is symptomatic of the cat going out though. How many miles on the car? More than 150,000? Likely its the catalytic converter. They are a consumable in your car. It will affect your mileage significantly while the code is on, and typically if it is the o2 sensor itself that has gone bad ( between 30 and 100$ per) and the cat is ok, if you don't fix the o2 sensor, the cat will burn up (cost between 200 and 700, and a bunch to swap out) Get it checked out, you're looking at more bucks the longer you wait
2/24/2019 6:07:06 AM •
American...
Answered
on Feb 24, 2019
