20 Most Recent
Franklin Industries Franklin Chef 75 lb. Storage Capacity Clear Ice Machine - FIM200 Questions & Answers
Were can i buy a water inlet for a franklin ice
Gold Star Restaurant Equipment
5 star rating 1 user rating
735 SE Morrison St, Portland, OR 97214
(503) 235-5756 Website.
They have everything new and good used, they can get your part. Please let me know how it goes, thanks for using fixya.com. Mike
6/6/2011 9:03:25 PM •
Franklin...
Answered
on Jun 06, 2011
I have a wine chiller
There are many different causes behind machine not cooling.
1. Defrost can be the cause for your refrigerator notcooling problem. To check to see if you have a defrost problem, look in thefreezer to see if there is ice build up on the evaporator cover. (Theevaporator covers are either in the back of the freezer or on the bottom of thefreezer).
2. If the condenser fan (the one under refrigerator) is notworking, the compressor will cut off on the overload. If the evaporator fan isnot running, there will be no airflow to the machine. First walk up to therefrigerator and listen to see if the fans (one in the freezer on one under thebottom) are running. If one is running and the other is not then get to the onethat is not running and see if something is blocking it. If there is nothingblocking it then replace it.
3. Dirty condenser can be the cause for your refrigeratornot cooling problem. If the condenser is dirty, the compressor will cut off onthe overload.
If theseparts working correctly, then probably the compressor itself is faulty. You needto replace it.
Hope this will help you. Good Luck.
8/25/2011 12:31:42 PM •
Franklin...
Answered
on Aug 25, 2011
